Door won't open from outside
Old Sep 6, 2006 | 05:04 PM
Craigo's Avatar
Has anyone ever run into this problem??? My passenger door won't open from the outside. I have a '96 Limited 4-runner. How easy is it to fix?
Old Sep 6, 2006 | 05:07 PM
Elton's Avatar
the rod inside the door may of broke
Old Sep 6, 2006 | 07:26 PM
profuse007's Avatar
pop off the door panel and cehck it out. theres a metal rod thats held on the latch by a plastic clip. if things are intact, the latch assembly might be an issue.
Old Sep 7, 2006 | 04:32 PM
drtoyo's Avatar
My plastic clip broke last week and I fixed with a zip tie. 1001 uses. I will eventually get to the dealer and buy replacement, can't be much.
Dennis
Old Sep 7, 2006 | 05:36 PM
TYOTA's Avatar
I bet its that stupid plastic clip. its allowing the bar to lengthen and not pull hard enough on the latch.
Old Sep 7, 2006 | 10:04 PM
profuse007's Avatar
those type of parts.... probably 5bucks for one.
Dennis
Old Sep 7, 2006 | 10:22 PM
Bob_98SR5's Avatar
i wrote a writeup on fixing the plastic clip. look in the tech section
Old Sep 10, 2006 | 05:26 PM
Craigo's Avatar
Thanks for all of the input. I will check out that tech section. I heard something rattling around this weekend when I had the window down and I think that bar is the cause.
cars-guy
Aug 16, 2020 06:59 AM
okamikai
Apr 30, 2018 10:19 PM
theking11863
Mar 19, 2016 09:36 PM
britishdudes2dr
Jul 25, 2015 06:47 AM
94yotaky
Jul 23, 2015 07:50 AM
