DIY tranny flush.
Old 01-20-2005, 02:14 PM
kevin444's Avatar
DIY tranny flush.
Does anyone know on a 3rd gen 3.4L which of the 2 hoses on the lower radiator is the recirculation/output line for the tranny fluid?
Thanks a bunch some pics could help!
Old 01-20-2005, 03:30 PM
MO-Runner's Avatar
On my '02 the hose on passenger side of radiator is from the tranny and
the one on the drivers side goes back to tranny or in my case to the TRD cooler.
Old 01-20-2005, 07:22 PM
dave89144's Avatar
Detach the hose on the right/passenger side of the radiator at the radiator.
I did the DIY flush last year, its a piece of cake. I ran a total of 16 quarts thru, 2 at a time.
Old 01-20-2005, 08:06 PM
kevin444's Avatar
soooo how many bottles of atf did you buy?
Old 01-20-2005, 08:08 PM
dave89144's Avatar
16 quarts/bottles of the Mobil 1 variety, around $80....
Old 01-20-2005, 10:02 PM
kevin444's Avatar
Geez id like to stay with AMSOIL but mobil 1 is alot cheaper.
Old 11-01-2005, 08:31 PM
theryanator's Avatar
How did you do this? Did you run them through using a machine?
Old 11-02-2005, 04:59 AM
GSGALLANT's Avatar
First of all, you need to drain the transmission pan (you should then remove the pan so that you can clean the particle magnets located in the pan and so you can clean or replace the filter screen. After that is done, reinstall the tranny pan, and top up the fluid.
Then, disconnect the tranny fluid return line coming from the radiator, and place that in a collection bucket. Start the truck and let the tranny pump out approx 1 quart of fluid into your bucket. Shut the truck off and top up the fluid in the pan again. Repeat this until you have gone through your 16 quarts. This will replace essentially all the fluid in your transmission.
ladybugRC
458
08-21-2020 10:41 AM
TheBFA
02-15-2020 06:55 AM
live4soccer7
05-11-2016 06:52 PM
Davebarbier
11-03-2015 03:28 PM
hiluxinargentina
09-30-2015 05:51 PM
Quick Reply: DIY tranny flush.
