difference between the R150 and R150F?
Old Nov 21, 2004 | 06:18 PM
1tonMike's Avatar
I currently drive an '89 Toyota 1ton pickup with a 3.0 V-6. It has the R150 transmission, the 2WD version of the R150F, used in 4x4's with the V-6. I have been kicking around the idea in my head that one day I would like to drop a solid axle in the front, but I've heard that you need to swap out the 2WD transmission for the 4x4 tranny and t-case. I was wondering since the two trannies are almost identical, could I get away with using the R150 hooked up to a Toyota t-case?
Old Nov 21, 2004 | 06:29 PM
kyle_22r's Avatar
i have a bit of a hunch that it might be as simple as a tailhousing swap. ask on marlin's board, he's great with these kinds of issues as he's the best toy tranny man on the planet.
i think the most desirable thing to do is find an R151F transmission and put it behind your V6. 23 spline output so you'll never break it
Old Nov 24, 2004 | 11:12 AM
1tonMike's Avatar
Thanks for the feedback.
Old Jul 1, 2008 | 12:02 PM
ToyPreRunr's Avatar
R150 vs. R150F
Did you ever get an answer if they are compatible? I have a 1999 V6 Tacoma 4x4 and a friend has an R150 tranny. I want to put my transfercase on his R150 and run it on my Tacoma. Will it work?
Kevin
Old Jul 3, 2008 | 02:30 PM
Adam F's Avatar
By itself, a transfer case will NOT bolt up to a 2wd R150 trans. You will at least have to have a 4wd R150F tailhousing and maybe a output shaft too.
Daenerysdad
Oct 1, 2015 07:33 PM
EatChipsNow
Sep 9, 2015 01:25 AM
viesail
Sep 5, 2015 04:23 AM
pplusent
Sep 2, 2015 11:56 PM
skypilot
Aug 25, 2015 01:09 PM
