Crickets in your clutch? Chirp, chirp, chirp… Fix’em like this. - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 08-30-2006, 04:16 PM   #1 (permalink)
So you have that cricket sounding noise chirping away from under your truck but if you just ever so slightly rest your foot on your clutch pedal it goes away? Drive ya nuts? ME TOO! First I tried the lithium spray into the throw out bearing through the rubber linkage boot… (http://www.yotatech.com/showthread.p...1&goto=newpost) that worked for oh, about a ½ a second… well 2 months & 600 miles but the damn crickets came right back!
So I found this post on 4x4wire and it makes such sense, so simple… take the little bit of slack out with the adjustment just like you do when you rest your foot on it, DUH! Check it out:
http://www.4x4wire.com/forums/showfl...5&o=14&fpart=1
This is strange and can't figure it out. When I drive along in my 2002 Toyo Tacoma I can hear a squealing noise. Similar, but lower then worn out brake pads. If I just rest my foot, very gently on the clutch pedal the squealing noise goes away. I don't really have to put pressure on the clutch pedal. Is there something that needs lubricating? I should also note this does not effect operation at all. No play in the clutch, no slipping, etc...
This is a fairly common issue. It is the throw out bearing; just adjust the linkage between the clutch pedal and master cylinder. Adjust it to make the rod longer; only adjust it to the point that the noise stops. This procedure has fixed my truck, as well as a few others. Mine was 40k miles ago and the noise hasn't come back.
Thank you for that information. Is this the proper procedure?
The clutch master cylinder has an actuator rod that connects to the clutch pedal. This rod has a lock nut on it. Loosen this nut and turn the rod to lengthen or shorten the pedal free play. Hope this helps.
Yes, that is the rod to adjust; it needs lengthened just to the point the noise stops.
Haven’t done it to mine yet but I will ASAP!
biGjOhn
SuaveGato is offline
Tags
2000, bearing, chirp, chirping, chirps, clutch, cricket, engine, making, noise, pedal, stops, tacoma, throw, throwout
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Chirp Noise 91TPU 86-95 Trucks & 4Runners 1 01-03-2007 09:20 AM
Front end squeak/chirp noise... Swede 95.5-2004 Tacomas & 96-2002 4Runners 10 07-21-2006 02:45 PM
chirp! lee 95.5-2004 Tacomas & 96-2002 4Runners 5 11-23-2004 07:28 AM
Turning Piezo chirp on Rayday81 95.5-2004 Tacomas & 96-2002 4Runners 2 09-19-2003 11:30 AM
Clutch chirp? kdeking 95.5-2004 Tacomas & 96-2002 4Runners 9 11-24-2002 04:57 AM
2009 InternetBrands, Inc.
