Cone Filter
Old 07-01-2002, 06:00 PM
turboale's Avatar
Cone Filter
Put it on today, sounds really good on the mid-high revs! Had a mounting bracket my dad made me left over from air horns on my old car that worked perfect for securing it. All I had laying around the garage was some rope, so that will have to do til i get something better. :rolleyes:
Old 07-01-2002, 06:38 PM
Toyota Punk's Avatar
What type of filter did you go with? It looks like the K&N cone but I could be wrong. Nice work none the less! Did you notice any perf gains? I saw a bit better throttle response and pickup when I added mine.
Old 07-01-2002, 07:54 PM
Adam F's Avatar
You guys dont think your just sucking hot air from the engine with no hood like the K&N kit provides? Ever thought of making something simmilar to that? Sucking hot air ain't gonna help with performance!
Old 07-01-2002, 09:12 PM
crash's Avatar
Those things only offer 1 thing, more air flow, but that is it. It will suck in the warm air, which is far worse than better airflow, and can suck in water easier also....
Old 07-01-2002, 09:18 PM
turboale's Avatar
yes, that is true... but, i'm not huge off roader (not forwarding any streams any time soon...) so i'm not to worried about that. I mostly like the sound it makes. It also supposidly helps fuel consumption... (less restriction) idono... i may switch back to the box while down in Savannah during the summer if its really that bad, but up here in the mtns it isn't bad.
Old 07-02-2002, 04:02 AM
BTOWN4RUNNER's Avatar
Hey, if you find it doesn't work, you can always take it off and put on he stock box. It is worth a try. I was going to get the same thing, but from what I had heard, the drawbacks outweighed the benefits, but hey, maybe you guys find the benefits more. I am interested in hearing any benefits that you may find. I am looking to get some more air into my engine and all I can think of now is drilling holes into my airbox. Let us know what you find out! Thanks! :fireman:
Old 07-02-2002, 01:12 PM
I'm with turboale - I don't plan on going through any kind of deep water with my truck. The possibility of water splashing up when hitting a deep puddle is not too severe because it's location is pretty well protected. Injen makes a heat shield for the filter, but I'm not too worried about it. There's a helluva lot more open air circulating in my engine compartment then 99% of the sports cars that generally use cold air intakes. I never expected any significant gain in anything from it, but it looks good, sounds good and as I said I did notice a little bit more throttle response. Maybe I'd benefit from the heat shield, but I'm not losing sleep over it.
Old 07-02-2002, 01:30 PM
Hey, it is always a good mod if you enjoy it and it sounds as if you do, so good job and I am glad to hear that you like it! :fireman:
JonG85
01-18-2023 04:31 PM
ladybugRC
458
08-21-2020 10:41 AM
Davebarbier
11-03-2015 03:28 PM
mreagen
10-05-2015 04:27 PM
shredder4286
10-01-2015 01:09 PM
Quick Reply: Cone Filter
