Coil replacement w/spacer kit?
Old Sep 6, 2006 | 07:58 AM
frodin1's Avatar
I've got a 00' Limited. I have a Daystar 2.5 spacer kit on it. I'm running 285's on her. The rear is begining to sag a little. Question is, should I replace both the front and rear springs at the same time? I do have a little bit of rubbing issues and i'm wondering if the PP springs will help that at all. They claim a 1" inch lift from them. I see alot of people recommending 99 coils, whats the best setup for these rigs to prevent the sagging from happening. What about shocks? Should I do these while i'm at it? I don't want to thrash my ride but I do want to fix the sagging issue so it doesn't happen again. Thanks for any help in advance!
Old Oct 10, 2006 | 08:48 PM
grandpasatsky's Avatar
hey I saw you have the daystar 2.5 spacers. I was thinking about getting a set for my 97' runner but are you haveing problems with yours?
Old Oct 10, 2006 | 11:43 PM
BeachRNR's Avatar
Since you want to get springs and shocks at the same time you might as well go with the tundra coils in the front with the OME's in the rear and tacoma shocks. In the end you will have a better ride for pretty much the same price.
That was what I was thinking about doing to my 97. I was going to get the 99 coils for the front with a spacer and for the back I was going to run the OME 890's with the Tacoma shocks.
After adding it all up i figured what I said in the first paragraph.
Go with the Tundra Setup.
Old Oct 11, 2006 | 12:05 AM
Elton's Avatar
threads over a month old pretty sure hes not coming back
Old Oct 11, 2006 | 12:09 AM
mpavolka's Avatar
Hey I would go with Tundra coils up front, but I wouldn't get 99' coils for the rear. I had the stock ones on mine and just like any other rear 4Runner coil made since 1990 they will sag eventually. After six years mine were sagging around 2 inches before I replaced them.
Old Oct 11, 2006 | 12:17 AM
BeachRNR's Avatar
Did'nt notice that, but I thought I saw a post by him recently.
Old Oct 11, 2006 | 12:18 AM
Elton's Avatar
his last activity: 09-12-2006 07:51 PM
Old Jan 19, 2007 | 07:58 PM
frodin1's Avatar
That's a big delayed negitve on the Daystar problems!
bigjstang
Jun 2, 2025 03:56 PM
mskalmus
May 28, 2017 07:51 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Jnkml
Jul 6, 2015 01:20 PM
Vargntucson
Jul 4, 2015 12:15 PM
