Chunks of metal in bottom of oil pan
Old 03-24-2005, 08:35 PM
pruney81's Avatar
Does anyone know what chunks of metal in the oil when you change it is? I've heard a bad connecting rod bearing, not sure though. Anyways, I think my car has a rod knock and I've seen metal chunks in the oil the last two oil changes. Well, it's a rebuilt engine, supposedly, so I've only changed the oil twice. 86 4Runner dlx stock 207000 miles 3100 on junk rebuilt
Old 03-24-2005, 08:38 PM
SoCal4Running's Avatar
Possibly timing chain guide pieces??? Hopefully!!
Old 03-24-2005, 08:43 PM
pruney81's Avatar
chunks of metal in bottom of oil pan
If I drain the oil into a bucket or whatever then dump it into something else there's all kinds of little metal chunks left in whatever I put the oil into. The engine also knocks or slaps pretty bad when I start it sometimes and it runs hot. I've got a new radiator, dual stage thermostat and water pump. I think the shop that installed my engine pulled a fast one on me. The knocking is especially bad after an oil change on the initial start up. 86 4Runner dlx 20700 miles 3100 on rebuilt, or is it?
Old 03-24-2005, 09:25 PM
DudeBud's Avatar
sounds like the chain guides might want to pull the cover and check
Old 03-25-2005, 03:57 AM
TechWrench's Avatar
I'd take it back to shop that did the 'rebuild', if you have any type of warranty. What you are describing, doesn't sound good to me.
Old 03-26-2005, 03:45 PM
pruney81's Avatar
86 22re rebuilt
Thanks, I'm taking back on tuesday, I've got a one year unlimited mileage warranty, but they are not very helpful at all
Old 03-26-2005, 04:18 PM
fadetoblack72's Avatar
Sound just like a rod bearing to me but i am no expert. Just had mine go last summer and i am putting in a reman now. You might want to take it to another mechanic and see what he says before returning to the one who "rebuilt" it. My mechanic had me start it and told me it was a rod bearing. It was a distinctive rapping sound.
Good luck,
Jason
Old 03-26-2005, 06:24 PM
pruney81's Avatar
bad rod bearing
I went to one mechanic in the town I live in and he told me that it was a rod bearing just from hearing what I described to him. I've already talked to the shop that claims to have rebuilt it and I'm basically going to keep going back there until they get it right. Either way if it is a rod bearing there's no way it was rebuilt. I think what they did was just slap a new oil pan on it and a few seals and call it rebuilt. They claimed that the pistons were bored over but it doesn't seem to drive like it to me. 86 4Runner DLX bone stock 207,000 miles
Old 03-26-2005, 07:40 PM
DudeBud's Avatar
I hope evey thing gets straghten out dont let them just roll a new bearing in make them build a new motor.all thoes tiny pices of babit might of messed up all of the other bearings. it can still be a rebuilt motor maybe someone messed up with the bearing sizes it happens. Thats why they should be cheaked with with plastigauge
Old 03-27-2005, 12:01 PM
pruney81's Avatar
rebuilt 22re
I'm gonna try to make them build a new motor, they're really not very helpful at all. In hindsight I probably should have spent a little more money and bought an engine from a reputable company. I spent 2100 bucks for the engine a clutch kit a water pump and they installed it too. I'll let you know next week, I'm taking it back on Tuesday.
09-04-2015 09:27 AM
thefishguy77
07-30-2015 10:59 AM
irritech
07-27-2015 05:15 PM
calderp
07-27-2015 09:58 AM
Gamble_STi
07-07-2015 07:54 PM
Quick Reply: Chunks of metal in bottom of oil pan
