Buying a 99 Runner
Old 05-26-2007, 06:08 PM
jm47's Avatar
Buying a 99 Runner
Hi Guys:I am thinking about buying a 99 Runner.I took it for a test drive today and everthing seems to be ok.The vehicle is extra clean with a few minor blemishes.The one thing that concerns me is the wheels seem a bit scratched and pitted.Is this something that can be corrected without getting too expensive?The vehicle has 92000 miles on it so the timing belt needs replacing also.Dealer is looking for $10k.Your thoughts/suggestions?Thanks...Joe
Old 05-26-2007, 08:26 PM
rocket's Avatar
Sounds pretty good. Most will agree that 99's are the year to get. You can always find another set of used wheels on Craigslist, eBay, or even here.
I see you've been a member since 2002..what else do/did you own?
Old 05-26-2007, 10:15 PM
X-AWDriver's Avatar
What trim level? Locker?
Old 05-27-2007, 09:47 AM
fotorunner's Avatar
Maybe it was driven on gravel roads. My 97 travels a min. of 10 miles of gravel every day and my wheels are all pitted up. It?s one of those things you can?t avoid if you are on gravel a lot. Depending on how bad they are probably the only thing you could do is replace them with aftermarket wheels
Old 05-27-2007, 05:03 PM
jm47's Avatar
Hi Guys:the Runner has a tow hitch with a bit of rust on it.Could salt water do that to the wheels?Thanks...Joe
Old 05-27-2007, 05:28 PM
rocket's Avatar
jm47, It would be nice if you responded to the questions & comments posted above. Also, where do you live?
MMA_Alex
25
04-18-2017 05:07 AM
Cplmike
07-08-2015 08:47 PM
Jnkml
07-06-2015 01:20 PM
toyoda8488
07-05-2015 10:18 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: Buying a 99 Runner
