Bud Built Clocking Adapter?
Hey all, I was wondering if the Bud Built clocking adapter will work on my '98 4Runner V6 5-speed?
I assume it would because arent the tranny and T-cases the same between the 4Runners and Tacos?
Thanks
Thanks
Originally Posted by BruceTS
Yes they will fit, I have one sitting here ready to install.......
I think Ill probably pick one up.
i've been thinking about this too...hmmmmmm
bruce, what all is involved in installing this? how will it work with your dual cases? or will it not even affect your tcases?
...and how about some opinions on the FROR clockable crossmember?
http://frontrangeoffroadfab.com/nfos...8fd3801b7e27a7
clocking adapter and crossmember in 1. hmmm....
There is some additional work required at install since the shifters will "clock" as well. Bud told me that this probably also requires at least a 1" BL.
I had already thought about the shifters, but Marlin can make you a new shifter bent for however much you clocked your case.
I wonder if you could get them legthened too between the body lift and the clocking you wouldn't be left with much length... I have a 2" BL now and wouldn't want it any shorter than it is.
ashamsuddin
17
01-13-2023 03:17 AM
hiluxinargentina
09-30-2015 05:51 PM
Cycles
09-29-2015 06:37 AM
Toys4parts
09-26-2015 01:56 PM
