Old 03-30-2016, 11:15 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tacoma Electrical Guides
Print Wikipost
best writeup for 3.4 V6 spark plug change?
Old 01-24-2009, 11:27 AM
Ron Helmuth's Avatar
Question best writeup for 3.4 V6 spark plug change?
go ahead I got the fire suit on...
I did search with terms like "spark plug change" and "Pictures spark plug" but of course did not find what I think I need...
I am inept with tools but my 16year old car crazy son will supervise me changing out my spark plugs.
I know I need a torque wrench and have the K16Tr11 Nippodensos ready and waiting. ($1.60 each at RockAuto. love those guys....)
I have done spark plug changes before but technology has changed significantly since my 72 Gremlin's 232 straight 6.
Will I damage my coil packs?
Can I do one plug at a time and minimize my wire swap risks? I should remove the negative battery cable first before commencing work?
Boss me around.... point me to threads I should have found I like pictures.....
teach me how to search and feed a village....I either get 4 pages of unrelated crap or "terms not found"
Old 01-24-2009, 11:36 AM
skjos's Avatar
http://www.4runners.org/writeups/sparkplugs/
What I would like to know is how you check and gap a dual electrode plug? A traditional spark plug gapping tool does not fit between the round center piece and the concave ends of the two prongs.
Old 01-24-2009, 01:02 PM
Rock Slide's Avatar
Ron, the above link should provide enough info for you. Also, take a look at this one: http://www.4x4wire.com/toyota/mainte...ep3.html#plugs. The fuel line method works great too.
skjos thanks very much I looked on T4R as well, But clearly did not find.
appreciate the link sir
per first paragraph the Nippodensos are pregapped at .044 so no need to gap.
Still I like the idea of checking the gap-and your point is still valid-
how does one check the gap on a dual electrode plug? Is that a specialized gap tool?
Old 01-24-2009, 01:06 PM
rock slide thanks for that link also
I had forgotten about 4x4 wire and those guys are most helpful. I like that idea of the fuel type hose to start the threading.
appreciate you guys stepping up to help me out.
I can handle this. Those pictures most helpful from Bob98SR5 writeup. This will not be hard. No I don't have to undo the negative battery cable.
Old 01-24-2009, 03:32 PM
Gerdo's Avatar
Do use a small amount of anti-seize on the threads and a dielectric grease on the wire ends.
Old 01-25-2009, 09:03 AM
yes it mentions that for the threads- and I have one of those handy dandy plug wire pullers so I don't damage them. thanks Gerdo
Old 01-25-2009, 12:06 PM
Maj
Maj's Avatar
After you loosen each plug a couple of turns, take a shop vac and suck out any debris to keep it from falling in the combustion chamber. The photo below is a good example of why you should use anti-seize.
Old 01-25-2009, 12:12 PM
Elton's Avatar
you gonna need a some long extensions a spark plug socket and a deep metric socket.... get the spark plug started with the spark plug socket then finish with the reg socket .... dont need a torque wrench just get it snug and go a half turn
pplusent
09-18-2018 10:02 PM
toyhaulert100
09-24-2015 07:55 PM
mordell
09-12-2015 10:13 AM
Tacoma1313
08-17-2015 05:44 PM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
Quick Reply: best writeup for 3.4 V6 spark plug change?
