Best location for new oil sender (Autometer oil pressure gauge) - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-18-2004, 12:41 AM   #1 (permalink)
Hey guys,
I'm getting ready to install my Autometer oil pressure sending gauge (#2634). Its electric, so no oil line coming into the cabin.
Which location is best to install the supplied oil pressure sender? A1 or A2? A1 looks easier because its relatively straight line with the wheel well access "hole" (the same hole I use to remove the oil filter)
For reference, "S" is the stock oil pressure sender
Also, I read that these two little 8mm allen bolts are loctite'd. what's the best way to de-loctite it? hopefully not heat b/c i dont have a torch!
thanks,
bob
Bob_98SR5 is offline
Old 10-18-2004, 06:49 AM   #2 (permalink)
instigator's Avatar
Bob those plugs are also british pipe threads, but you could get a 3/8 pipe(us) to work. i plumbed my bypass filter from port A2 on you pic
__________________
97 fzj80 w/TP(gulf coast 01jr) oil filter
96 4runner (2wd) w/TP(frantz) oil filter
instigator is offline
Old 10-18-2004, 11:05 AM   #3 (permalink)
instigator,
ok great. thanks for the info. that A2 one looks rusty. i read that both are a b###h to get out. maybe i'll try A1 since it doesnt look as rusted
bob
Old 10-18-2004, 12:04 PM   #4 (permalink)
NorCalVP's Avatar
Send a message via Yahoo to NorCalVP
Quote:
Originally Posted by Bob_98SR5
Hey guys,
thanks,
bob
Bob, I've also got mine on A2, this is on my Tacoma though...
Steve
__________________
1997/04 Tacoma SAS D-Cab Supercharged v6, 5 speed, Marlin Crawler MC09 Serial number 001. and lots of other goodies.
NorCalVP is offline
Old 10-18-2004, 04:09 PM   #5 (permalink)
Steve,
Ok, thanks. Looks like A2 it is!
Bob
Old 10-18-2004, 06:46 PM   #6 (permalink)
FattyCBR's Avatar
A2 is where I have mine, also A1 is the oil pump so I would not tap into it. Good pic BTW, best I've seen of that area.
__________________
Milan
_ _ _ _ _ __ _ _ _ _ _ _
Support our troops!
'98 4R Limited
'82 Toy 4.3, SM465, D20 <- Sold
FattyCBR is offline
Old 10-19-2004, 01:47 AM   #7 (permalink)
Quote:
Fatty,
Thanks for the warning re A1. I thought that there were two plugs you could tap next to the oil sender unit. I guess I read incorrectly.
(phew!)
Bob
Old 10-19-2004, 06:41 AM   #8 (permalink)
I agree about it being the best photo I've seen on a Toyota forum...
But I'm wondering (just for the record) - what's the problem with using A1 'cause it's on the oil pump? Erroneous readings? Failure risk? Bad karma?...
EnolaGaia is offline
Old 10-19-2004, 04:16 PM   #9 (permalink)
superjoe83's Avatar
Send a message via AIM to superjoe83
i believe if you take that plug out, it will be followed by a spring and a ball, thats most likely the pressure relief valve for the pump
__________________
- Joe
1984 SR5 4runner, 22re, 5-speed, chevy 63"s, rears up front custom pack, BBCS shocks, 2" BL, 5.29's, welded rear, Detroit in front, Longfields, IFS Rear, 39.5x13.50x15 IROK's, Marlin's High Steer, MC07 with stock cases, Marlin's cross member, tube bumper, Warn XD9000, Allied Beadlocks
1999 Taco 2.7 5-speed, LCE Header, Jardine 2.25 Cat-Back, 3" Downey Coilover, 33x13.5 Toyo MT's, ARB Bull Bar, Retrofitted Acura TL HID Projectors with 50W ballasts and 50W DL50 Philips 3900k bulbs
superjoe83 is offline
Old 10-20-2004, 10:07 AM   #10 (permalink)
Quote:
OK - I see... Thanx for the clarification....
Old 10-20-2004, 03:13 PM   #11 (permalink)
kevin444's Avatar
Send a message via AIM to kevin444
how the install went? any pics of the gauge in action?
__________________
02 4runner conversion complete!
kevin444 is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
oil pressure sender longhungsilver 86-95 Trucks & 4Runners 0 03-09-2007 10:46 PM
Need 89 oil pressure gauge and sender wildman326 86-95 Trucks & 4Runners 0 12-16-2006 10:08 AM
Where is my oil pressure sender located base554 95.5-2004 Tacomas & 96-2002 4Runners 1 03-18-2006 04:00 PM
Auto Meter Electric Oil pressure/Water temp gauge sender install 1988 3.0 1st gen CappyKD 95.5-2004 Tacomas & 96-2002 4Runners 1 06-16-2004 07:42 PM
2009 InternetBrands, Inc.
