Auto to Manual trany conversion..i need help!
Old 12-09-2009, 03:40 PM
eastsideyota's Avatar
so i just saved up enough money to do a trany swap. i just dont know how to start going about it and what exactly i need. has anyone done this and has a list or something of what i need to get and what the best parts would be??
im looking to finish it by the end of december
let me know of any info!
Old 12-09-2009, 03:43 PM
1990yota-pickup's Avatar
make sure you measure the lenght of the trannsmissoins so you will know if you need a longer or shorter driveshaft.
Old 12-09-2009, 03:53 PM
ok. do you know of a good website to get all the micalanious parts? i know craigslist is a good one
Old 12-09-2009, 04:17 PM
a good salvage yard.. or your local toyota junk hoarder guy that has about a dozen yota lying around in his yard... but wont sell a one of them.. you see ppl like that no mater what state you are in.
i would suggjest to get a digtial camera and take as many pics as possible so you can always go back and compare...
check you parts manual books too
Old 12-10-2009, 10:15 PM
Mylesofsmyles's Avatar
Is there no progress on this swap? Should it be any more difficult than a transmission swap on, say...a Miata?! A manual transmission, driveshaft, clutch, pressure plate, flywheel, slave and master cylinder and pedal...and a shifter? Bolt everything to spec, wire in a clutch/neutral safety for the park sensor and wire in the reverse light?
I looked under the hood of an 02 and the firewall doesn't appear to be drilled through for the master cylinder but shouldn't be too difficult.
Old 12-19-2009, 01:19 PM
did u get everything swapped out
Liadrin
04-25-2022 02:54 PM
AndYota
08-10-2015 09:19 AM
jbandt
08-03-2015 03:23 PM
TransAmBandit
07-28-2015 11:30 PM
KBar
07-13-2015 06:01 PM
Quick Reply: Auto to Manual trany conversion..i need help!
