ARB compressor - where to install?
just curious (and need inspiration), where did you install your ARB compressor? pics would be nice too if you could. I've got a mini compressor from ARB and havin a tough time deciding where to put it... what would give the best performance? would outside of the engine bay (i.e. towards the back of the vehicle) be out of the question? - might be because of noise / heat? goin to moab for easter weekend so any info before then would be great...
thanks!
thanks!
my buddy has his installed in the rear hatch of his jeep cherokee, you can only hear it cycling on and off when you have power going to it. when i get my ARB im going to mount mine inside my rear hatch
hmmm.. i'm not too worried about the noise if it's just when it's giving power. it might even be cool, like when you hear turbo or a supercharger whine. does it give off heat that could damage the plastic or anything?
One other thing to consider is if a seal goes out in the locker gear oil can get pushed up the air line and the soleinoid will puke it out the relief valve. So that can be a bit messy for an interior mounting.
i've got my compact compressor mounted on the passenger side...i think just between the abs module and the airbox. mounted on the wheel well hump. inside the cab...the novelty of compressor noises and blow off will wear off quickly. depends on how many lockers you're plumbing to it. mines only for the front, so it made more sense to mount it as close to the front locker as possible...
i can have some pix of where i mounted it tomorrow...
i ended up mounting it to the drivers side fan shroud. It was an east place to put it w/out having to move anything around or building a mounting plate. So far its held up welland ive had it there for a few years.
skoti89
07-08-2015 12:05 AM
1998, 4runner, arb, box, cherokee, compressor, install, installation, installed, installing, jeep, mount, pictures, tool, toyota
