Anyone ever do SAWS with a spacer?
Old Nov 22, 2004 | 09:34 PM
ianshoots's Avatar
So I'm waiting for UPS to bring my rebuild kits so I get can get to the used SAWS I bought from Jboy, and whilst surfing trying to figure out what to do with the rear (see probs in sig) I took a look at the Daystar spacers that wheelers off road was selling, and I thought, "I wonder if I could run a set of the 1" top out spacers with my saws thereby combining them for a lift similar/equal to cranking the SAWS up all the way, yet mainting some of the "droop" that cranking them up loses".
Yep, thats what i thought.
Anyway......Would this work? Does it make sense? Is it a stupid idea? I did a search of the forum and found it mentioned only once, as a passing suggestion made by Mad Chemist.
thanks for looking....
Old Nov 23, 2004 | 02:16 AM
Bighead's Avatar
I believe RTDawgs and Schaefer ran the SAW/Revtek topout spacer combo (I'm sure there were others). They might be able to give you some info on the setup.
Old Nov 23, 2004 | 02:48 PM
ianshoots's Avatar
With any luck they'll see this and chime in, otherwise I'll PM 'em/
Old Nov 28, 2004 | 07:14 PM
ianshoots's Avatar
Bump a dump :bounce2:
Old Nov 28, 2004 | 08:04 PM
Ducky's Avatar
Wherd' ya get the rebuild kits and how much? How often do you all recommend a rebuild?
Old Nov 28, 2004 | 08:11 PM
ianshoots's Avatar
I bought them from Camburg engineering, I wouldn't be suprised if Demello offroad had them too. I hear something like ever 30,000 miles is recomended, probably depends on how hard they get used.
I paid about $50 shipped for kits (two shocks worth)
Old Nov 28, 2004 | 09:17 PM
RTdawgs's Avatar
Finally saw this. Yes i ran a revtek top spacer on top of the SAWs, just got longer bolts.
However i cannot imagine using a 1" spacer, it would be too long to fit back in the thing i think.
Old Nov 28, 2004 | 09:22 PM
ianshoots's Avatar
How'd that work out for you? I believe it was the revtek spacer I was checking out on wheelersoffroad. If not 1", what size did you run, 1" was the only size I saw there, though i suppose I could check directly with revtek.
Thanks
Old Nov 28, 2004 | 09:42 PM
RTdawgs's Avatar
revtek was 1/2". it worked great, i really enjoyed it.
also, i think the design of the 1" daystar is different so check with that.
Old Nov 28, 2004 | 09:49 PM
ianshoots's Avatar
I'm glad you spotted this, thanks for the insight.
Were the necessart longer boltsa/studs hard to find?
Old Nov 29, 2004 | 05:56 AM
RTdawgs's Avatar
nah i find them at lowes.
Old Nov 29, 2004 | 06:07 AM
Mad Chemist's Avatar
Ditto on what RT said. I'm still running the Revtek top out spacer with my SAWS, though I think it was 3/8"- I think it was ~25 bucks from Revtek. It did seem to soften the suspension a little by allowing you to put less tension on the spring. I also got longer bolts from Lowes.
Ducky, you might be able to get away with just getting a fresh charge of Nitrogen as well, don't the SAWS hold ~200 PSI or something like that?
Old Nov 29, 2004 | 06:11 AM
RTdawgs's Avatar
yes they are 3/8" but the 1 and 2 numbers are much closer together than the 3 and 8 keys so I am lazy.
Old Nov 29, 2004 | 06:27 AM
Its monday, I forgive you.
Old Nov 29, 2004 | 04:16 PM
Bighead's Avatar
Yes, they came from the factory charged at 200 PSI.
4x4YOTA
Aug 23, 2016 09:08 AM
hiluxinargentina
Sep 30, 2015 05:51 PM
89YodaRunner
Sep 30, 2015 02:18 PM
PNW94Runner
Sep 29, 2015 02:55 PM
crash813
Sep 27, 2015 07:15 AM
