Another Question
Old 11-05-2003, 09:07 AM
NVRSASTK's Avatar
Another Question
I have a 99 Limited 4 wheel drive. How do you know if it has a fatory locker in it or not?
Old 11-05-2003, 09:08 AM
Jonathan's Avatar
There is a switch inside the truck that will say RR Diff Lock. It's located on the left -hand side of the dash.
SLC Punk's Avatar
There should be a button on the dash, just left of the steering wheel. By the dimmer.
It should say RR DIFF
Or look at your rear diff for the locker motor.
Old 11-05-2003, 09:09 AM
SLC Punk's Avatar
Beat me to it!!
Old 11-05-2003, 09:11 AM
NVRSASTK's Avatar
Thanks alot guys
Just curious which models normally have that? I thought being a Limited I woould have that stuff I guess not... That sucks
Old 11-05-2003, 09:32 AM
Jonathan's Avatar
Check out Jalaber's site he has a bunch of info on the 4Runner on there and you cna probably find what your looking for a lot easier. But to answer your question, they made them from 99 on up to 2002, but I think you had to either order it that way or it was just luck of the draw. The e-locker only came on the 4x4 Runners and was not specific to either the SR5 or the limited, it just depends on how it came from the factory. I may be a little off on some of this but just check that site and it should help you out i believe.
Old 11-05-2003, 09:52 AM
CTB
CTB's Avatar
Actually, I think they were only available from 1996-2000. After that came the multi-mode AWD/4WD system.
Just trying to keep you Carolina guys straight......
Old 11-05-2003, 09:54 AM
Jonathan's Avatar
HAHAHa, yeah you're probably right Cody, haven't really looked too hard into it, all i know is that I want one
lectric80
08-11-2015 12:02 AM
makemusic116
08-02-2015 05:23 PM
makemusic116
08-02-2015 04:40 AM
TJWilly
07-31-2015 02:05 PM
4Runnin2000
07-29-2015 06:09 PM
Quick Reply: Another Question
