Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
97 runner - clutch fluid replacement?
Just curious, but wth do you drain out the old fluid?
I made the mistake of looking in the clutch fluid reservoir this morning, since it looked a little low. Aside from actually being a little low (just under the 'min' mark), the fluid was BLACK. Given that new DOT3 fluid has a rather pleasing translucent, light shade of brown, I think it's prolly time to flush that sucker out.... Anyone know where the DOT3 floweth from?
__________________
'03 Tundra - Maroon SR5 Access Cab, V8, LSD, most of the good stuff. Soon to get a minor lift, sat radio, and front tint. Check out http://www.cosportbikeclub.org for great info on riding in Colorado and other bike goodies. http://www.teamskinny.net - The best motorcycle racing site in the world! http://www.racing2savelives.org - Racing 2 Save Lives - Motorcyclists making a difference! |
| Sponsored Links |
#2 (permalink) |
There is a bleed nipple on the slave cylinder. Get as much out of the master with a syringe first and then fill the master with clean fluid and bleed just like brakes. Open bleed valve, push clutch pedal down, close bleed valve while holding pedal down, then release pedal. Repeat until clean fluid comes out of bleed valve. Be careful not to let master get empty. It is also a good idea to put a piece of hose on the bleed valve to direct the fluid into a container.
As you can probably figure out this is a lot easier with 2 people. |
#3 (permalink) |
I also have a speed bleeder that I use on the bikes, basically it connects to the bleeder nipple and sucks the fluid out. Makes the task a ton easier, probably would here too. Still helps to have 2 people though to make sure the reservior never empties, since that's bad.
thanks!
__________________
#4 (permalink) |
Yeah I did this recently too. Just hook up the speed bleeder to the slave nipple and open the valve while keeping the reservoir full.
As was mentioned, suck the crap out of the res first. ![]() |
#5 (permalink) |
Roger that. Crap suckage will commence!
__________________
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Leaking clutch fluid | G's 84 Runner | 84-85 Trucks & 4Runners | 2 | 07-13-2007 06:50 AM |
| Clutch leak/Dark clutch fluid | geoduke | 86-95 Trucks & 4Runners | 2 | 04-04-2006 07:51 PM |
| Our new 97' Runner.. and our 97' F140 4X4, comments | lllateralus | 95.5-2004 Tacomas & 96-2002 4Runners | 11 | 04-21-2005 09:42 AM |
| Clutch fluid ?'s | CMD93 | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 03-15-2004 03:18 PM |
| Clutch fluid... | rpeAMP | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 08-21-2003 08:26 PM |
