96 4runner braking vibration
Old 11-16-2008, 11:10 PM
brystal's Avatar
I have a 96 3.4L 4x4 4runner with a vibration in the pedal and steering wheel during braking at anything but low speeds.
My 4runner was stolen last winter and fortunately and unfortunately they found it, with minimal visible damage. They repaired the cosmetic stuff and the more we drove it the more things started to go wrong (of course insurance wouldn't cover any of it).
Anyway after we got it back when braking there was tremendous vibration that shook the whole dash and steering wheel. I guessed the rotors were warped and replaced those and found that my steering rack bushings were also shot and replaced those too.
Everything was fine for a while now I have the same problem all over again (not quite as bad). I don't really want to replace rotors every 8 months and was wondering if anyone had any insight into this problem.......
Thanks in advance.
Old 11-16-2008, 11:47 PM
Flomaster's Avatar
do the Tunda brake upgrade and be done with it.
-=jason=-
Old 11-17-2008, 04:19 AM
GSGALLANT's Avatar
-=jason=-
^x2...
Old 11-17-2008, 07:55 AM
hross14's Avatar
X3 and take it to a body shop to get it aligned and checked out--and use search function
Old 11-17-2008, 02:11 PM
brystal's Avatar
I did get it checked out when I got it back from the body shop and they didn't have much to say about the brakes, other than a slight vibration(I don't think they drove it very fast) the alignment was fine.
I was wondering if there might be some other contributing factor to the vibrations other than insufficient stock strength in the brakes. I had like 190,000km on the stock rotors with no problems, then only like 7 or 8,000km before I had the problem again on new rotors (aftermarket slotted and cross-drilled).
What year of Tundra rotors and calipers are being used?
Old 11-17-2008, 03:30 PM
DYNNOMMYTE's Avatar
be sure to get the rears checked as well... if the rear brakes are not working well, then the fronts are taking the brunt of the job of stopping the truck, getting over heated etc, etc, etc.
Old 11-17-2008, 07:03 PM
SoCalPaul's Avatar
Vibration while braking is almost always the rotors. The after market rotors may or may not be any good. If you got drilled & slotted rotors, you may also have more aggressive pads which could cause more heat buildup in the rotor. Try some OEM or Brembo rotors. You might also check the wheel bearings & rod ends.
Paul
Old 11-17-2008, 07:12 PM
racermp's Avatar
brembo oe rotors (cheap) and akebono ceramic pads. did my sis's 4cyl. never had a prob again. waiting to do my 6 now
Old 11-17-2008, 09:14 PM
One_96TR4's Avatar
many ppl have good result with some brembo blanks and hawk pads, or any good pad (OE maybe). I actually did the Tundra upgrade though.
06-01-2021 01:51 PM
Johntom240
7
07-13-2015 12:18 AM
87turboPA
07-12-2015 07:49 AM
87turboPA
07-09-2015 05:58 AM
Jnkml
07-06-2015 01:20 PM
Quick Reply: 96 4runner braking vibration
