90w in the Transfer Case?
Went to change the fluid in the transfer case on my 91 4Runner, V-6. The manual says it should take Dexron II, but the case is currently full of gear oil. Is the manual wrong, or do I have the wrong fluid in the case?? TIA
What transmission do you have? I believe that if you have an Automatic tranny, the transfer case should take ATF fluid. Those of that have manual tranny's use gear oil in the transfer case. Needless to say, you should follow what is in the owner's manual.
It is the manual tranny. I'm sure that the transfer is supposed to have the 90w in it, but the damn Haynes manual is sectioned out strangely, and reads different than it intends to. Just wanted to double check. Thanks
I thought you meant owner's manual, not the Haynes.
What does that say? I think my manual transmission requires 75W-90. I would have to check it to be sure. I put some kind of synthetic in long ago, but forgot what kind.
Toyota trucks with automatic transmissions use ATF in their transfer cases.
Haynes breaks it down like so (take note of the spacing).
Transfer case oil:
......1985 and earlier.................75w90
......1986 through 1989
.............Manual trans...............75w90
.............Auto trans...................Dexron II ATF
......1990 and later
.............4 Cyl Eng.....................75w90
.............V6 Eng.........................Dexron II ATF
I have a '91 with a V6. How would you read this chart?
Transfer case oil:
The specs here are from the factory manual, and I put them onto a picture of the Amsoil that I use.
http://pnw4runners.com/tech/2nd_gen_fluids.jpg
Manual transfer cases do use gear oil, autos use ATF.
Weird huh?
Weird huh?
Dug up an old thread as to not start a new one for my possibly stupid question. Searched and everyone says that auto tranny transfer case takes atf fluid and front and rear diffs take hypoid and regular gear oil (forgot which for which). Is it ok to use 75w regular gear lube for all three? Would it mess up anything if there was something different in there like atf in the transfer case and then it was replaced with regular gear lube?
Oh sorry if I wasnt clear. Not saying that they have anything to do with each other. I just wanted to know if it was alright to put regular gear lube in all three things (the diffs and the transfer case) in an auto because everybody mentions that the transfer case in an auto takes atf and that one of the diffs should use hypoid gear lube and the other just regular gear lube.
ALL 4Runners 96 and up use gear oil in the transfer case
95 and previous Autos only used ATF
Go to Bob's write up
hiluxinargentina
09-30-2015 11:12 PM
hiluxinargentina
09-30-2015 05:51 PM
Phantez
09-30-2015 08:24 AM
Toys4parts
09-26-2015 01:56 PM
