54mm socket needed!
Old Nov 8, 2004 | 06:43 PM
Ilovemountains's Avatar
Unhappy 54mm socket needed!
Hi guys, I took off tomorrow hoping that the local Auto Zone would have a 54mm socket for rent or for sale so I can finally get my Brembo/Performance Friction/inner outer wheel bearing job going but I guess I was wrong! Does any one know where I should look locally for a socket this large? Does any one have one I can borrow “Ill pay 2 way shipping"? I would hate to buy one, I know I won’t need it again for years but if I have to I guess I will! Does any one know of any other way to get the hubs off? I mean any other tools that I may have handy; I need to find out before I start pulling things apart! Thanks again, Matt. Oh what size in inches would this equate to, I cant think right now
Old Nov 8, 2004 | 06:46 PM
fiveofeen's Avatar
25.4mm in 1 inch
Old Nov 8, 2004 | 06:48 PM
AW1090's Avatar
I bought the 2 1/8 cause I couldn't find a 54mm either, but it seemed to work fine
Old Nov 8, 2004 | 06:49 PM
fiveofeen's Avatar
just wondering whats the benefit to manual hubs?
Old Nov 8, 2004 | 07:18 PM
AW1090's Avatar
I think the manuals cause less wear on the cv's......much less wear on a lifted IFS for sure. http://www.4x4wire.com/toyota/maintenance/front_end/
check this one out....all the info I needed. It was a really good write up...hope it helps
Old Nov 8, 2004 | 09:15 PM
toy283's Avatar
There is also the slight gain in power. I notice it when I have the hubs locked on my '85, there is a noticable power drop due to the frictional losses of the front end components turning.
Old Nov 8, 2004 | 10:09 PM
Blackulua's Avatar
Knuckle Service Tools
We get lots of calls asking where to get the special tools needed to service Toyota knuckles. With some searching we found these high quality service tools. The scale allows you to measure the knuckle shim preload. To use: remove tie rod, attach the scale to the steering arm. Then adjust the shims until it takes 12-15lbs of force to rotate knuckle.
Snap-On 54mm Hub Socket $24.99
Knuckle Pull Scale $9.99
Found these at Marlin Crawler Website
Old Nov 9, 2004 | 05:14 AM
waskillywabbit's Avatar
Talking
SEARS Craftsman 2 1/8" socket w/ 3/4" to 1/2" adapter so it will fit on a 1/2" drive ratchet $30
If you got manual hubs and need it now, just BUY one, you'll need it again.
54 mm = 2.125984252" = 2 1/8"
Old Nov 9, 2004 | 05:20 AM
sschaefer3's Avatar
Is that the socket that goes on the bug huge nut on the Toyota streight axle? If so I need to get one too.
The FJ-62 and your 85 have baiscally the same axle except the 62's is longer and the diff is 9".
Old Nov 9, 2004 | 05:22 AM
Talking
Yep, that is the socket that goes on that bug huge nut! You need to get a spring scale too...
Old Nov 9, 2004 | 09:22 PM
Flamedx4's Avatar
Use a screwdriver and a hammer and some common sense. It ain't rocket science.
Old Nov 9, 2004 | 09:27 PM
toy283's Avatar
A cheaper alternative. $12.94 shipped
Old Nov 10, 2004 | 05:09 AM
Talking
Yeah, common sense, a hammer and a screwdriver works real well on a torque wrench. :pat: Good thing you don't build rockets either.
"Common sense sure ain't too common."
Old Nov 10, 2004 | 08:01 AM
Flamedx4's Avatar
[[ a hammer and a screwdriver works real well on a torque wrench]]
EggZactly! Torque wrench, breaker bar, monkey wrench, all the same... LOL. You guys just can't take a joke...
Old Nov 10, 2004 | 09:14 AM
Question IFS dont need these right?
I wont need one of these scale when I do my wheel bearings on my 88 will I???
bigjstang
Jun 2, 2025 03:56 PM
icentropy
Sep 16, 2020 02:47 PM
Road Bull
Oct 10, 2015 04:55 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
mickyd9990
Jul 6, 2015 09:01 AM
