4WD Light Won't Turn Off
Old 11-27-2004, 02:17 PM
Scary Mc's Avatar
I spent a few hours today drivining the truck to and from xc skiing and had it in 4WD much of the time due to a few inches of snow on the road. Once the snow started to clear I shifted out of 4WD and the indicator light did not turn off, I shifted back and forth a few times to no avail, the 4wd indicator light wont turn off. It feels like 4wd is disengaging at least...
Anyone know what the problem might be? It's an '04 Taco 5spd w/ less that 10,000 miles.
Thanks~ Gary
Old 11-27-2004, 03:11 PM
WATRD's Avatar
Did you try backing up a few yards to see if it would "break loose"? If not, give it a shot.
Old 11-27-2004, 03:13 PM
Scary Mc's Avatar
Yup, didn't work.
Old 11-27-2004, 03:21 PM
WATRD's Avatar
Bummer. With that few miles on it, it might not be worth messing around with. With a brand new truck like that, make it the dealers problem.
Old 11-27-2004, 03:57 PM
Scary Mc's Avatar
I went for a short test drive to make sure 4wd is not engaged, and it's not. I'm able to take tight turns on pavement w/o any steering feedback. As soon as I pull back the 4wd lever the steering feedback in turns starts up.
It's not a big deal but it still pisses me off. I suppose it's possible that a sensor somewhere is clofgged w/ ice or snow.... If it doesn't fix itself by Monday afternnon I'll be going by the dealer.
Thanks~ Gary
Old 11-27-2004, 06:32 PM
NorCalVP's Avatar
Thanks~ Gary
Gary, The light comes on when the ADD is engaged. So your transfer case may be out of 4WD, but the front axle isn't. Take it back to the dealer and let them fix it...
I think starting in 01 they went to an electrical actuator for the front diff, (pre 01 should be Vacuum). I had a few problems with my Vacuum actuator, until i cut it off...
Steve
Old 11-27-2004, 06:50 PM
Scary Mc's Avatar
Tell me more of this cutting....
Is there something I can unplug and reset so I don't hurt it driving around tomorrow?
Old 11-27-2004, 07:21 PM
NorCalVP's Avatar
http://www.norcalttora.com/projects/...1/P0000662.JPG
http://www.norcalttora.com/projects/...2/P0000678.JPG
You won't hurt anything by driving around with it activated, just make sure the T-case is not engaged...
Steve
Old 11-27-2004, 09:14 PM
ekim121's Avatar
Before you do any cutting on a vehicle that new I'd check to see what warranty implications it would have...as long as it's under warranty take it to the dealership and let them figure it all out...I sure wish I had that luxury sometimes...
Old 11-28-2004, 02:22 PM
jackamot's Avatar
i know this will sound odd but maybe you want to check your fluids i had mine changed out and the light finally went out .... although it doesn't come back on now when i go wheeling . it's worth a shot and it's good matainece for your rig being that you'll might be wheeling a little more now that the snow is here .
Old 11-29-2004, 05:32 PM
Scary Mc's Avatar
I've got an appt. w/ the dealer on Wednesday and a loner truck to drive while they have it. I'm also going to change the fluids tomorrow since I'm off work and it's not snowing anymore. Hopefully that will help things. The t-case and tranny still have the factory fluid in them so maybe it's time after almost 10grand on the odometer...
So, if the truck were not in warranty what would i do to fix this problem?
I appreciate the help.
~Gary
Old 12-01-2004, 10:59 AM
Scary Mc's Avatar
Just got a call from the dealer. They opened up the front diff and found that the truck was shifting out of 4wd and that the diff was not engaged, the the problem is the acutator that tells the 4wd light to turn off is not working.
Of course they don't have the acutator in stock, so they said to come pick up my truck and they would order the part and let me know when it is in.
FWIW~ Gary
ashersullivan88yota
01-18-2022 05:37 PM
mskalmus
05-28-2017 07:51 AM
TokyoD23
07-12-2015 06:01 AM
Kalihi,HI
07-09-2015 04:29 PM
raiderhawks00
07-08-2015 06:23 PM
Quick Reply: 4WD Light Won't Turn Off
