Tundra coils netted -.5" lift...WTH?
Old Dec 1, 2004 | 10:21 AM
HaveBlue's Avatar
Hey, all-
I recently switched from OME 881s up front with Pro Comp ES3000 struts and a 1.5" Cornred Spacer, to Tundra 4WD coils with new Pro Comp ES3000 struts and a 1" Cornfed spacer. I haven't liked the Pro Comps but they were a $20 hold-me over until I can get a pair of OME struts. Going by what everyone else has said about the Tundra coils, I should have gained 2.25" with the coils alone and another 1" with the spacer, right? I measured from floor to fender before I remove the OME coils/struts and got 38". After the Tundra coils with spacer, I'm now at 37.5". What'd I miss?
Do I need a longer strut? Who makes a strut that will acommodate a 3.5" lift?
Old Dec 1, 2004 | 10:28 AM
bamachem's Avatar
Did you use TRD coils? The 2wd NON TRD coils are 1/4" shorter than the 99 4runner coils...
Old Dec 1, 2004 | 10:29 AM
snwbrdpunk16's Avatar
Did you measure in the same spot? 3.5 inches is gonna be tuff on your CVs.
Old Dec 1, 2004 | 10:34 AM
HaveBlue's Avatar
I bought a diff drop. I haven't installed it yet. And I measured in the exact same spot.
Old Dec 1, 2004 | 10:40 AM
bamachem's Avatar
The TRD (2wd and 4wd) Tundra coils net 1.5". 3/8" spacers net another 1/2".
A 1" cornfed spacer would give you 2.5" of total lift with the TRD Tundra coils. You had 1.5" form the OME 881's and 1.5" from the cornfeds, giving you 3" total. Now you have 2.5", so you lost a half-inch. Sounds right to me.
Old Dec 1, 2004 | 11:29 AM
HaveBlue's Avatar
D'oh! :pat:
When you put it that way, it all makes sense.
Thank you!
sandyota
Feb 4, 2021 11:16 AM
Sleaker
Aug 26, 2020 06:03 AM
Massmayhem247
Jul 24, 2015 12:07 PM
Suprarossa
Jul 6, 2015 05:21 AM
Vargntucson
Jul 4, 2015 12:15 PM
