3rd gen Downey/ Bilstein
I currently have Bilsteins all around my truck. But after ordering my new rear coils from Downey (rear 3.5 HD with limitng straps). I found that the current Bilsteins I have on there dont offer enought travel for the new springs (part number for the rear BE5-2451). In fact, some one sugested that it could break or snap during heavy articualtion due to the limited travel.
So I plead to all thoes guy who are running the downey coils in the rear with Bilsteins what part number is it?
Just to note that my current setup is '97 4runner 3.4L Sr5. and the rest is found in my sig. Thanks for the help guys.....
Common guys help me out with this one. Im gonna put me new springs in on Wed. I dont wanna brake anything if my rear articulates to much. So I gotta know......Thanks guys and gals
Is there a difference b/w 2wd vs 4wd rear Bilsteins? Maybe you need the ones for the 4wd, if they are in fact longer...If they are the same part, then it shouldn't be a problem as many people are running this set up. Install the limit straps that come with the kit and consider extending your rear bumpstops and you should be set.
I have the same Bilsteins on my Runner. 2450 in front and 2451 in the rear.
I have the PP coils in front and the 3.5" Downey in the rear.
https://www.yotatech.com/forums/f2/downey-coils-19112/
I haven't had any problems. Just put the Limiting straps on that Downey provides with the coils.
Im getting all this for $320 installed. The Downey coils, Downey limiting strap, E-brake bracket, fix both of my rear axel seals, Drain and fill rear diff, and install and bleed my wheelers steel front brake line. And rember I live here in hawaii.
He got them off downey for $200 somthing, check thier web site. The reason I can be sure, if that it costs so damn much to ship things to hawaii.
Its on the second page of thier suspension parts. I'll go find you the link. BTW I like the Jaos grill, I wish i could afford one. Got a few questions, where did you get your alternator. I need a new one to keep up with my sounds, check my setup in my sig.
http://downeyoff-road.com/Suspension...s/Springs.html
there ya go bud!
there ya go bud!
matmattmatthew
10
02-09-2021 04:15 PM
Swampwalker
10-12-2015 09:49 AM
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
09-24-2015 03:30 PM
runnermedic
13
09-21-2015 05:20 PM
