3rd brake light problem
Old 06-04-2014, 07:30 PM
97yota4unner*limited's Avatar
I have checked all my fuses and even replaced the socket to the light and my 3rd brake light on my 1997 4runner is not working . Could it be something with the wiring? I have never had a problem with it before so that's y I'm confused. Please help thanks.
Old 06-05-2014, 01:24 AM
wyoming9's Avatar
Red face
Yes it could be a damaged wire problem
Could be a bad box of bulbs??
Do the rest of the brake lights work like they should ??
Have you tested for system voltage at the third brake light when the brake light switch is closed ??
Anything else in that area also not working??
Drill any holes or any other work before this started??
Old 06-05-2014, 03:25 AM
RAD4Runner's Avatar
Yep. Before you throw parts, time, money into a problem, verify that parts are broke before you replace them. Verify that parts are good before you install them. Verify that socket is getting power before you suspect the bulb.
Next to our senses, the Digital multi-meter is the best electrical diagnostic tool for our classics. If no DMM, Harbor Freight is your friend.
Old 06-05-2014, 08:23 AM
Thanks and yes every other light works on the front and back and inside the 4runner. The socket looks a little burnt but the bulbs I put In it work not tested the sockets to see if it's getting power will do that today. Will let you all know if I get to the problem of it.
Old 06-05-2014, 11:59 AM
wyoming9's Avatar
Red face
Unless you have a very strange 4Runner you really should not have brake lights in the front or inside the cab.
Then I keep a open mind people do strange things so anything is possible.
So that said.
Do your other brake lights work like they should??
At this time we are concerned just with the brake lights!!!
Old 06-05-2014, 12:57 PM
Lol my headlights and interior lights all work and my brake lights work my third brake light is not working but has before this problem.
Old 06-05-2014, 12:58 PM
I didn't say I had more brake lights . My post said all my other lights work. Lol my headlights and interior lights all work and my brake lights work my third brake light is not working but has before this problem.
Old 06-05-2014, 01:30 PM
RAD4Runner's Avatar
Hey, don't we have blinkers on the dash? So why not brake lights on the dash so we know that we're braking?
After all, a Prius has a beeper inside to remind driver that he's backing up-DUH! B it has no audible alarm outside to alert someone that the quiet car is backing up-DUH2X!
Goodness frickin gracious - the pointless things that designers do.
LOL!
97yota4unner*limited,
A third brake light is merely tapped from one of your main brake lights. Shouod not be to difficult to trace the wires.
wyoming9.
I'll keep you posted IF and when I install the third brake light on my first-gen - LOL!
Old 06-05-2014, 01:37 PM
Ok thanks I'm right now out here tracing the wiring down to the third brake light and I'll let you all know if I get it working again. Thank you all
Old 06-05-2014, 05:50 PM
habanero's Avatar
While you're looking peek under the rubber boot between the hatch and body. Broken/cracked wires are really common there and it'd only take a few seconds.
We have do to have break lights on the dash RAD4Runner! A brake light might be nice too, I suppose.
Old 06-05-2014, 06:02 PM
I have tore her apart and no broken wires or anything . I'll give it another shot tomorrow going buy new bulbs maybe it's a wrong bulb I put in it.
Old 06-05-2014, 07:48 PM
RAD4Runner's Avatar
[QUOTE=habanero;52201317]While you're looking peek under the rubber boot between the hatch and body. Broken/cracked wires are really common there and it'd only take a few seconds.
LOL!
Did you make any voltage check like we suggested?
Old 06-05-2014, 08:17 PM
Everything is checking out fine I am going to check the bulbs tomorrow and then see if that fixes it and then I'll let you all know if I got it.
Old 06-11-2014, 12:56 PM
Finally found out what was the problem to my brake light. Thanks for all the help.
Attached Thumbnails 3rd brake light problem-image-1423576437.jpg   3rd brake light problem-image-1633511600.jpg
Old 06-11-2014, 02:42 PM
RAD4Runner's Avatar
Cool. Yep, like habanero said, that flexing bunch of wires.
Old 06-11-2014, 02:49 PM
Yeah I had to pull off the tape on it because the first time I did I didn't pull it up far enough and couldn't see anything . Had to take a few days off of it and all but I am one happy momma again knowing that someone can't use the excuse my brake lights are not working now..
Old 06-11-2014, 06:33 PM
habanero's Avatar
Looks like you fixed more than your brake light if you dealt with all those breaks. Good on you! And yay a momma that ain't afraid to give it some thought!
My build thread is full of odds and ends fix-its, somewhat decent table of contents on post 2, and pics. Kinda like a lot of Yotatech is. Also, is that a snort hood on your 97?
Old 06-11-2014, 06:38 PM
Yes a lot of brakes on it lol. All lights and brake lights are now working no problem. Not afraid of anything when it comes to cars and it is a snort hood
Old 06-11-2014, 06:57 PM
habanero's Avatar
Cool!
ashersullivan88yota
01-18-2022 05:37 PM
06-01-2021 01:51 PM
mskalmus
05-28-2017 07:51 AM
jerusry
10-19-2015 05:28 PM
Jnkml
07-06-2015 01:20 PM
Quick Reply: 3rd brake light problem
