265/75 r16
Old 10-02-2007, 02:59 PM
LJ_24's Avatar
265/75 r16
will these fit in a '97 4runner 4wd?
Old 10-02-2007, 03:05 PM
wormhole's Avatar
That's what i'm running on my 96, with no problmes.
Old 10-02-2007, 05:36 PM
LJ_24's Avatar
96 is a 3rd gen right? jus to clear up confusion...
Old 10-02-2007, 05:37 PM
jjrgr21's Avatar
some rub some don't, at the most you may half to work on the pinch weld
Old 10-02-2007, 06:01 PM
trd_4runnin11's Avatar
Sorry for the stupid noob question and for the thread hijack, but what the hell is a pinch weld??
I'm going to be going with a 3" lift on my 98 4Runner and some 285/75's in the spring and from what I've been hearing im going to need to do something with this pinch weld. Pictures would be wonderful.... Thanks!!
Old 10-02-2007, 06:21 PM
skjos's Avatar
The pinch weld is basically the seam between the underbody and the outerbody. Its where the inner and outer bodies are pinched together, it runs along the underside of the body between the two wheel wells. If you have running boards it is not visable from the outside, you have to be under the truck to see it (I think - I never had running boards).
Old 10-02-2007, 06:32 PM
wormhole's Avatar
Here's a picture or two for reference. And yes a 96 is a 3 gen (it was the first year of the 3rd gens)
Parking lot shot:
Flex/stuff shot, no problems with clearance:
You should be fine but before you leave the tire shop make sure all is well and if any changes to the pinch weld or if you have rubbing issues get them address (like the others have said).
Old 10-02-2007, 06:49 PM
jjrgr21's Avatar
skjos nailed it, go to pirate or ttora or here for that matter, plenty of info on pounding them down..
Old 10-02-2007, 07:12 PM
LJ_24's Avatar
Parking lot shot:
thnx...nice 4 runner!!!
chadbobb
39
12-06-2006 03:57 AM
briang
08-18-2006 11:06 AM
mtbikejeremy
03-10-2005 01:39 AM
sdh1019
01-13-2005 10:50 PM
Quick Reply: 265/75 r16
