2 flat tires. Tire Sizing Help guys! QUICK!
Hey guys, today, not 1, but two falts, yes thats right 2!!!
So what I need from the YT community if the largest tires I can fit on an 04 Double Cab PreRunner Tacoma with no lift? Any chance I can fit 31's in there? Any ideas??? I gotta get em in the morning, help please guys!!!
~Chris
~Chris
265/70/16's.
I just measure, from thr ground up they are like (measured the spare, its the only full tread tire on the truck) 30 ish inches.... there is still almost 3" of room arond them in the wheel wells, there is no reason I shouldn't be able to fit 31's in there right?
What about 32's?
Whats the metric equivalent of a 31? 32? anything in between?
What about 32's?
I searched, tire size calculator and found
https://www.yotatech.com/search.php?searchid=2283457
then went to this thread
https://www.yotatech.com/forums/show...ize+calculator
and found this
http://www.miata.net/garage/tirecalc.html
and found this
and found this
You should be able to fit 265/75R16s just fine (which are 31.6 ~ or about 32").
yeah I got a good tire calculator, just thought I would ask the pro's. I think I am going to with the 265/75/16's, going with the Kuhmo Road Venture A/T's... What do you guys think?
May be a dumb question here, but what is the tire load rating on your rig now? A? B? C? D? E? the heaver the load rating the or further down the alphabet E=10 ply tire it will be a noisy tire but will take a beating You may find some in a F ply. Don't know if that size will be avab. TJ.
if your looking for cheap mud tires, wal-mart carries contintal super sports which wear pretty good, and are pretty aggressive offroad, the only down fall is that they are a bit noisy on the street, my buddy runs them on his frontier and he loves them, plus its wal-mart you can take anything back. yeah you should have no problems running 265 75 16
Thanks guys! I did settle on the Kuhmo Road Venture A/T's in a 265/75/16 variety. $92.00 a tire, $235 for the pair mount balance (lifetime balance) and the orad hazard warranty. I'll let you know what I think.
EDIT - I forgot you had a prerunner so I guess it's a 2wd so you're good. You just don't want to run mismatched tires on a 4wd.
I hope I misunderstood what you said but did you only get 2 tires? If so, don't run it in 4WD until you get the other 2 that match. Going up in size almost 2" on one end can put your drive train in quite a bind if you run it in 4WD like that. Again, hope I misunderstood...
06-01-2021 01:51 PM
skoti89
07-08-2015 12:05 AM
