GeoRoss' 1986 4Runner Rehab
Old 01-09-2017, 03:18 PM
  #41
GeoRoss's Avatar
Originally Posted by GeoRoss
I had sort of a belated "Eureka!' moment today. I have had a transmission whine for some time. It happens during deceleration in 3rd or 4th and goes away with the clutch pedal in. I assumed I had a bad input bearing and have half heartedly been looking for another W56B. Then today I just put together that the noise appeared sometime after I put the OME spring in. I'm betting that my pinion angle is off. As I understand it, the pinion should be horizontal. Is that correct? I really hope this is the problem. Shims are not on easier to put in than a new transmission, but a heck of lot less expensive.
I'm getting slow on the uptake. DOH!
In preparation for a highway trip I lubed up the 4Runner. I thought I had greased the u-joints when I put on the new OME leaf springs. I hadn't. I greased the heck out of them. The deceleration noise has been reduced greatly. I know now it is likely a pinion angle thing. I am planning on pulling a leaf. I'll address it with shims at that time..
Old 06-05-2017, 09:07 AM
  #42
GeoRoss's Avatar
Well, I've run the medium duty OME rear springs for almost a year. I've carried weight, articulated the suspension, etc. They really haven't relaxed much so I'm going to pull a leaf. I thought about doing this when I did the initial install.
My question is, will I end up destroying the center pin when I do this? I seem to recall it is riveted in. I just want to have some replacements on hand when I do this if needed.
Old 06-14-2017, 09:45 AM
  #43
GeoRoss's Avatar
Well, this is a tiny update. Last winter before a road trip I greased the driveline and chassis. I went to do the IFS and found it didn't have zircs, but plugs. I could easily get to the top, but the bottom was more tricky. Being in a hurry I skipped it.
I finally got around to replacing the plugs with zirc fittings as I was changing the wheels/tires. Here is were it gets funny, I spent an hour trying to thread a zirc into the lower arm. I finally realized if I just turned the wheel it would be easy.
I did find that the lower arm was pretty hard to squeeze a little grease in. The rubber felt pretty empty so I'm guessing clogged with dried grease. I'm also pretty sure I'll need to do some front end work soon if the swaybar bushings are any indication.
Old 06-14-2017, 10:32 AM
  #44
coryc85's Avatar
Yeah, sometimes common sense escapes me too when I'm elbow deep in grease and dirt.
Old 06-20-2017, 01:33 PM
  #45
GeoRoss's Avatar
One step forward, one step back. It is 112° today so the AC as been on high a lot. I've always had a terrible rattle when doing that. Today I found it, the defroster vents rattle. Some green felt and all is good.
While dropping the kids off it hit a bump, heard a thump and then a shatter. In the rear view mirror I saw stars sprinkling on the road. The PS mirror fell out of the housing. These are electric mirrors off a 1989 I found at a junkyard. I love these style of mirrors and I'm not hopeful I'll be able to find someone to cut a replacement mirror. Time for some eBay I guess.
Old 06-20-2017, 07:09 PM
  #46
rustED's Avatar
That sucks about the mirror glass. Might check your local auto glass installer, years ago My passenger side mirror fell off and I just had the local auto glass place cut out a new one. Installed it was like $20.
Old 06-21-2017, 07:21 AM
  #47
GeoRoss's Avatar
Thats my plan. I am hoping it is that easy.
Old 06-28-2017, 12:05 PM
  #48
GeoRoss's Avatar
I removed the lower/smallest overload spring. It didn't do much on the height, but it took most of the harshness out of the ride.
Old 07-03-2018, 04:09 PM
  #49
GeoRoss's Avatar
Well the 4Runner is still just dandy. Interestingly I found another set of electric mirrors. Happiness again when I change lanes. I found out what my off-throttle transmission whine was. I replaced the shifter bushing (from Marlin) and no more deceleration noise.
I've had a little bit of intermittent high idle. I tracked that down to a sticky dashpot. I'll keep lubing it until it completely stops. It is mostly gone.
I did develop a hard cold start only when temps are below 60˚F. I do need to track that down, but I guess I have until late October to fix that. I think it is either fuel pressure or my ICV. I don't have a start-up high idle, but that predates the cold-start problem. Seat-of-the-pants HP feel makes me think it is better if I leave the key in the ON position for 30 seconds or so before starting. It runs fine now and I'll sort that out later.
It does need body work and paint. My original plan was to do the exterior and then the interior from a logistics point of view. Sadly, my slush fund/mad money for fun stuff keeps getting depleted by the real world, new roof, new HVAC, and a few other things. Plus, I've been thinking that this might be something I want to tackle myself. I'm somewhat handy, what the hell.
Sooooo, to keep some semblance of forward progress I moved to the interior. My 4Runner is a DLX model with the 3/4 door cards. They are in good shape, but the asshat PO put some sort of weird outdoor carpet additions that were tek screwed on. Plus the DS door is a replacement from a full door card SR5 that had a speaker cut out. Door cards on eBay are made of gold and bitcoin so I decided to make my own.
Here is the first one. It isn't perfect but not bad for a first stab. Details for the build can be found here.
Old 07-03-2018, 06:44 PM
  #50
Melrose 4r's Avatar
Wow! Nice work on the door cards.
take it from somebody in the middle of a repaint, you could do it yourself with good results if you are patient and use quality materials.
and it’s less work if you don’t plan to change the color.
Old 07-08-2018, 07:21 AM
  #51
GeoRoss's Avatar
Thanks for the complement, I’m 1/2 way done on the PS door.
The only reason I don’t want to paint the 4Runner myself is time. I foresee it taking a full week or more if I devoted full time to it. In real world scheduling that becomes months. I still plan on doing it though, I just need a better place to work.
Old 07-08-2018, 02:59 PM
  #52
Melrose 4r's Avatar
George, you are absolutely right about that! That’s the exact situation I am in right now. Even though I got the right tools to do it, I don’t have the space to paint the whole truck in the garage so I’ve been doing it in parts, hood and fenders first, doors and tailgate next, then I will probably paint jams, roof and rear quarters last and have to shoot those outdoors.
I started body work in March. Thought I would have it done in June. Life gets in the way and as I got into it, I decided to spend more time to ensure better results.
Old 07-24-2018, 03:48 PM
  #53
GeoRoss's Avatar
Attempt #1 at recovering the dash is done. I learned somethings and can do a better job. I don't know if I'll use what I have and try to camouflage my mistake or find another donor.
Here is what I started with and the results. Details can be found here.
Attached Thumbnails GeoRoss' 1986 4Runner Rehab-img_2471.jpg   GeoRoss' 1986 4Runner Rehab-img_2472.jpg   GeoRoss' 1986 4Runner Rehab-img_2484.jpg   GeoRoss' 1986 4Runner Rehab-img_2485.jpg
Old 07-25-2018, 08:14 AM
  #54
jakey poo's Avatar
Not perfect but for a first attempt I'd say it looks pretty dang good! Better than I could do lol
Old 07-25-2018, 12:04 PM
  #55
RAD4Runner's Avatar
Looks good. That's how I plan to do mine as well. I'll be extra careful around the crack as learned from your experience.
Mountain Cop
442
04-10-2019 06:29 PM
CHEEZE
58
06-18-2016 02:06 PM
shrockworks
ShrockWorks 4x4 Products
11-04-2011 11:52 AM
jjrgr21
56
11-02-2009 12:55 PM
ADH8796
12-12-2007 04:54 PM
Quick Reply: GeoRoss' 1986 4Runner Rehab
