| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Thin wheel spacers?
__________________
My Build Thread The 4Cruiser: 98 4Runner SR5, 5VZ-FE, Sonoran Steel 1.2, BCC custom swing-arm rear armour, full Budbuilts, 285/75R16 Goodyear Duratracs, extended diff breather, airbox deckplate, red LED cluster, console,Wabfab front discos, Warn M8000 winch, Shrockworks full hoop, PIAA 520s and 510s, Stubbs HD-SKO Sliders, External tran cooler, tundra brakes and 5.29s and ARB lockers next |
#2 (permalink) |
ive been running 1/4 wheel spacers for over a year now with no issues. i was thinkin about going to the one inchers but these are all i need to clear my tires and it still keeps them just under the fender flares. sorry thats a little off topic. get em. just check torque regularly.
__________________
My Build Thread for sale. very cheap, almost free. 2002 4runner limited running boards (golden pearl) free to a good home. or any home at that 2002 runner stereo with 6 cd changer and external amp. |
#3 (permalink) |
x2 on re-torquing them. Any time you run spacers, it's a good idea to check the torque regularly.
__________________
87 4Runner, 22re, 5 spd, 4.88, ARB rear, Mile Marker PE8000, Downey Header, TG Sliders, 3" BL, Home Fab Front and Rear Bumper, WabFab Bikini Top, Rustoleum OD Green. Build Thread 98 Tacoma Prerunner, 2.7, 340k. 91 4Runner, V6. 5 speed, Pro Comp lift, 33's, Rock Crawlers. Sold. |
#4 (permalink) |
I've run 1/4" wheel spacers on and off for probably 12 years, on- and off-road, no problems, as long as you have enough threads for the lug nuts to grab onto and check the torque periodically.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
#5 (permalink) |
Great. 20mm of thread engagement remaining (i think they're M12s?) should be plenty. What brand do you guys recommend?
__________________
My Build Thread The 4Cruiser: 98 4Runner SR5, 5VZ-FE, Sonoran Steel 1.2, BCC custom swing-arm rear armour, full Budbuilts, 285/75R16 Goodyear Duratracs, extended diff breather, airbox deckplate, red LED cluster, console,Wabfab front discos, Warn M8000 winch, Shrockworks full hoop, PIAA 520s and 510s, Stubbs HD-SKO Sliders, External tran cooler, tundra brakes and 5.29s and ARB lockers next Last edited by ESQ; 08-26-2009 at 10:01 AM. Reason: typo |
#6 (permalink) |
Check out wheelers offroad. They sell them for 5 bucks a piece.
__________________
2004 3.4l Taco TRD SR5 Lil' bit-o-Lift, 32" General Grabbers, Softopper, 05TRD Wheels 95.5 2.7L Taco (RIP) Burned up!! |
#7 (permalink) |
Sweet. Ordered.
__________________
#8 (permalink) | ||
Lordco sells them for $7-12 IIRC. They do make your steering want to follow grooves in the road too due to you alterning the scrub radius (http://www.familycar.com/Alignment.htm). I'm picky, this bothered me, but probably wouldn't be noticeable to most people.
__________________
1990 Toyota 4Runner 22RE 5spd *Aussie Locker*York OBA* Quote:
Quote:
More info on 4Runners |
#9 (permalink) |
big o tires sells the 1/4" for less than $4 each
__________________
i drive by brail. Rock Solid Motorsports http://www.rocksolidmotorsports.net/ http://www.lunatic4x4.org/forums/forumdisplay.php?f=45 |
#10 (permalink) |
i got mine at pepboys. they were kinda pricey but i had to have them right away.
__________________
#11 (permalink) |
I doubt the scrub radius would be noticeable on such a wide tire with only 1/2in wider track. It also puts the distance between the tires on each axle back to equal length at rest given the suspension lift.
__________________
