Is chunking normal for MTs...
My Firestone MTs got a lot of nicks and cuts from the Big Bear trip. Also, I lose some rubber off the lugs.
Is this normal? Ahriman has the same tires, and I noticed the same problem with his.
Should I be concerned? Does MT/R have this problem?
Each of my super swampers is missing at least 3-4 whole lugs and at least 5 more are partially gone. Happens with all tires however, the more aggressive the tire the more surface area and access there is to the side of the lug to rip it off.
loi, i think you should just donate them tires to me and the wheels
actually just get them balanced and rotated after each run you do. I always do and if your alignment goes to whack after a run, get that done too!
welp I get unlimited balance and rotation w/ discount tire/america tire so i might as well take full advantage
i know loi got it at the same place too so i figure he might as well do the same thing.
hiluxinargentina
09-30-2015 11:12 PM
charlie_fong
09-27-2015 10:06 PM
