4runner tire & wheel modifications?
Old 06-04-2009, 11:15 AM
psudds87's Avatar
I dont know a lot when it comes to trucks so im here today just recently joined wanting to know the maximum wheel and tire size I can put on my '99 runner. Im going for a buffer look. I want to put all black wheels on and some bigger tires.
Old 06-04-2009, 02:29 PM
Tubbyfatty's Avatar
SEARCH! Its been covered, no, beat to death.
Old 06-04-2009, 03:45 PM
eric-the-red's Avatar
Beat way, way beyond death.
psudds87, I realize you're new here but that is by far the most asked question on the forum. On a stock 3rd gen you can fit a 265/75R16 with no rubbing. You may be able to go a bit bigger on a 99 as they had the taller springs.
But like Tubbyfatty said a quick search will give you more info than you can read
Old 06-04-2009, 06:16 PM
psudds87's Avatar
Thanks bro.
Old 06-23-2009, 06:47 PM
paynemw's Avatar
so i have a 2000 4runner SR5 4x4 and I also have but and getting rid of a 1990 chevy k1500 with the stock aluminum 16in rims wrapped in 265/75 Kumho Road Venture AT's.... and i checked the Pro Comp Wheel conversion chart for bolt patterns and am supper suprised but it says that the 4runner and the chevy have the same bolt pattern. I am stoked because the Kumhos are brand new and why not just throw my Kumhos and rims on the the 4runner... is it possible? if not why? the 4runner has 22575r15... help me!
Old 06-23-2009, 06:52 PM
Ardent's Avatar
Bolt pattern might be right, but you have to make sure that the backspacing would also be right. Oh, and I think that the 3rd gen's had the 16" wheels to clear the brakes, but maybe someone with more 3rd gen experience could chime in on that.
Old 06-24-2009, 03:48 PM
KVRunner's Avatar
Should be the same bolt pattern if the chevy rims are 6X5.5. At least i am pretty sure that is right.
Old 06-24-2009, 04:28 PM
The centre hole on the Chevy rims will probably be too small, but the bolt pattern is the same.
Old 06-25-2009, 05:02 AM
emptypockets's Avatar
The only way to know for sure it to test fit one. The bolt pattern is the same, but I'll bet the backspacing will be off. I'm not 100% sure about the hub diameter either.
06-01-2021 01:51 PM
skoti89
07-08-2015 12:05 AM
skoti89
07-06-2015 07:45 PM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: 4runner tire & wheel modifications?
