Swapping a 350 in 85 4runner wiring questions - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Engine Swap Talk > Domestic Swaps
Welcome to Yotatech!
Welcome to Yotatech,
Old 12-29-2008, 04:02 PM   #1 (permalink)
Just took the 22re out of my 854runner. Putting in a chevy 350. I was wondering if anyone could help me figuring out what wires under the hood I could get rid of? Any help would be greatly appreciated!!
LouisianaToyota is offline
Old 12-30-2008, 10:25 AM   #2 (permalink)
Adam F's Avatar
Send a message via AIM to Adam F
Carb on the 350?
I just did the same thing.
You can get rid of virtually ALL of the wires coming from the ECU.
I did this, but had to run 3 or 4 new wires.
I ended up having no ignition power. I ran a power wire from the AM1 80 main fuse under the hood to the ignition.
I also ran a toggle switch to a relay, the relay to the HEI distributor coil. Powered the relay from the AM1
I kept the stock starter solenoid wiring intact, so I can turn the truck over with the keyswitch.
I kept the stock wires for the headlights/turn signals, horn, and temp/oil sensors. All of these wires are on a separate harness than what comes out of the ECU.
I ran a new power wire from the battery to the AM1 fuse and to the starter. Ran a new ground cable from the battery to the frame, frame to the block, and frame to the body.
If you have any other questions just ask.
Adam F is offline
Old 12-30-2008, 04:29 PM   #3 (permalink)
are you still using the factory in tank fuel pump?
Old 12-31-2008, 08:32 AM   #4 (permalink)
Adam F's Avatar
No. Thought about it, but chose against it, for a few reasons.
I'd have to buy a pressure regulator to limit the pressure to 5-7psi for the carb. Regulators are like $75
Then I'd have to wire it up to yet another switch and relay. I already have one switch for the ignition power, and another for the fan power. Dont want another.
Its not really nessisary when you can just use the stock mechanical pump. I see no advantage using an electric pump with a carb on a mild engine.
Plus, I was able to sell the pump for $25
What I did was removed the pump from the bracket, found one of the steel lines (previously the return line I think) that reached the farthest down into the tank, traced that line to the front of the truck, and plumbed that into the carb. My only worry is that, without a fuel sock in the tank, it could pick up debris, but I should be able to see debris in the clear "G2" fuel filter right before the carb.
Adam F is offline
Old 01-23-2009, 03:24 PM   #5 (permalink)
Ron's 85's Avatar
Quote:
Originally Posted by Adam F View Post
Carb on the 350?
how is the tranny holding up to the v8 i just took that out to run a turbo350, i love the b&m ratchet.
Ron's 85 is offline
Old 01-24-2009, 01:57 AM   #6 (permalink)
Adam F's Avatar
I havent had enough time on it yet to say anything. Maybe 100 miles.
It has held up to about 5 burnouts though
It will be fine though. I'm using the R150 V6 transmission, which is the same trans used in the Supra, known to hold up to 600hp.
The 4cy trans will not last though.
Adam F is offline
Old 01-24-2009, 07:23 PM   #7 (permalink)
Ron's 85's Avatar
thats true!! good work buddy!
Ron's 85 is offline
Old 01-28-2009, 06:01 AM   #8 (permalink)
MaXXis85's Avatar
Send a message via AIM to MaXXis85
Any updates on the swap? Looks like I will have to go check it out in person. I am also leanin towards a SBC swap. It will be fuel injected though.
__________________
2005 K2500HD LQ4/80E/263/9.25/10.5/4.10's/285 Buckshots
1989 Toyota Pickup/3VZ-E/R150F/VF1A/8.0 Locked/8.0 Locked/5" SAS/3"BL/38 TSL'S
MaXXis85 is offline
Old 03-08-2009, 04:40 PM   #9 (permalink)
camo31"10.50"'s Avatar
so im lookin to do this to my '86 ext cab 4x4 DLX pickup..its carb'd..so no ECU and wiring BS...want to put a mid 80's carb'd 350 or 305 chevy on it..i now know i would want to go with a R150F tranny..lol..i would have used my 4cyl tranny..what about stuff like the axles and cv's...are they holdin up good???..how about the frame??? thanks for the info
__________________
FOR SALE 1986 Ext. Cab 4x4, rebuilt 22R, 5spd, 31x10.50 X-Terrains FOR SALE
1992 SR5 FO RUNNA V6, 5 speed, 4in. trail-master lift, 33x12.50 BFG muds, 4.56 gears!!! and an IMMACULATE interior..yes..you should be jealous
"Its still a toyota man.. Dont deprive it of its capabilities.."
"If you can read english, Thank a teacher...If you can speak it, Thank a soldier!!" Kelli Ruark-2009
camo31"10.50" is offline
Old 03-08-2009, 08:58 PM   #10 (permalink)
Adam F's Avatar
Keep it mild and go easy on the skinny pedal and you should be OK.
That being said, its VERY hard to keep out of the skinny pedal. I'm already looking into making a tracbar setup to cut back on wheel hop (so I can do some REAL burnouts)
Adam F is offline
Old 03-09-2009, 12:52 PM   #11 (permalink)
yea..i love my skinny pedal...lol..but i think..as long as im not hard on it..i'll be ok..thinking maybe a 305 chevy will be a better choice..lol..little less HP...im not looking for a HARDCORE motor..i just want something stock..stock 350 is about 260HP...which is WAYYYY MORE THAN ENOUGH..with that much HP..it'll make that toyota fly down the road no problem at all
__________________
Old 03-10-2009, 03:55 PM   #12 (permalink)
Adam F's Avatar
260hp stock 350? what vehicle did it come from? that number is pretty high unless its an older musclecar.
Adam F is offline
Old 03-31-2009, 01:08 PM   #13 (permalink)
Ron's 85's Avatar
does anyone know where my electronic choke should wire to?
hard wire?
or on the keyed ignition on the column?
Ron's 85 is offline
Old 03-31-2009, 05:34 PM   #14 (permalink)
Adam F's Avatar
one wire goes to ground, the other goes to any keyed 12v hot. i used the same wire that goes to my hei distributor.
Adam F is offline
Tags
1985, 350, 4runner, 85, bracket, build, chevy, electronic, engine, hei, locations, runner, swap, trans, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
92 4runner w/ Chevy 350/350 $3200 cracker_1 The Classifieds GraveYard 0 04-28-2008 09:12 AM
350 in a 200r4. Some questions.. laidout95 Engine Swaps 2 12-19-2007 07:10 PM
'71 LandCruiser chevy 350 replacement Wiring Harness dusktugdawn Offroad Tech 2 08-19-2007 09:57 AM
1971 LandCruiser chevy 350 replacement Wiring Harness dusktugdawn Pre 84 Trucks 6 08-03-2007 04:13 PM
A couple of questions re swapping guages and clinometer dirtykaw 86-95 Trucks & 4Runners 5 02-27-2006 07:54 PM
2009 InternetBrands, Inc.
