Diesel Swaps Diesel engines
22 re to om617
Old 08-08-2015, 09:10 AM
hawks7106's Avatar
22 re to om617
im looking into swapping my 22 re to a om617 just trying to see If I can get so help or someone lead me into the right direction on motor mounts wiring and a tranny adapter plate ive seen the ones for the 5 speed but mines A340F auto any help would be really appreciated thanks in advanced
Old 08-12-2015, 05:09 PM
usmma2013's Avatar
There are several OM617 conversion threads here, and on 4btswaps.com and on Peachparts. I'd recommend reading through these they will answer your questions. There is no one-size fits all solution for this swap, everyone does it differently and that is half the fun!
There is definitily no bolt-in solution for motor mounts - it depends what you want to accomplish. The hardcore 4x4 guys like the stock Toyota mounts or bushings that don't tear. Mine is a DD and only light 4x4 use so I used the fancy Mercedes hydraulic mounts to curb the vibrations.
To my knowledge, nothing exists for a A340. If you want an automatic, use a 700R4 with an adapter kit from Bendtsens adapters. The 700R4 has excellent ratios for the OM617, and is robust and shifting is controlled by a single TV cable. Otherwise the easiest would be picking up a w56 5 speed and using the 4x4labs kit.
Old 09-28-2015, 06:59 AM
hawks7106's Avatar
ok thanks
Old 12-16-2015, 11:01 PM
Cadin's Avatar
FYI: Member pyrojoe22 on this site has just recently started making a bolt in option for the motor mounts...
https://www.yotatech.com/forums/f37/...46/index2.html
Old 12-17-2015, 06:42 PM
jennygirl's Avatar
Yeah those motor mounts look great, they are adjustable so you can position the motor forward or backward. Killer idea considering how people need to customize placement based on transmission.
I haven't done much reading on auto transmissions with the om617. If it were me, I would see if the mercedes auto would fit?
Old 05-16-2016, 05:44 PM
pyrojoe22's Avatar
Project Truck now For Sale!
Glitch
Last edited by pyrojoe22; 05-16-2016 at 05:46 PM. Reason: Mobile site glitch. Didn't mean to post here
pyrojoe22
Vendor Advertising
51
04-09-2018 06:10 AM
mountainbrew
Diesel Swaps
09-20-2015 07:12 AM
RobotMoose
Diesel Swaps
08-02-2015 11:00 PM
89lc
Diesel Swaps
02-20-2013 12:03 AM
Quick Reply: 22 re to om617
