94 4Runner engine swap - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Engine Swap Talk > All Other Toyota Swaps
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-13-2008, 07:24 AM   #1 (permalink)
buckaaron's Avatar
Send a message via MSN to buckaaron Send a message via Yahoo to buckaaron
Hey everyone I have a 1994 $runner with the 3.0 engine and it has like no power when i get to higher speeds. I bought the truck with 150,000 on it and it has a ticking sound to it. I paid $1000 for it. I am thinking about swapping the engine for a 4.3 vortec. Is this a good engine to be putting into it. My buddy has the engine and it only has like 90,000 on it. Also what kind of modifications do i need to do and do i need to replace the tranny and what else would i have to change. i can do all my own conversion.
buckaaron is offline
Old 11-13-2008, 08:18 AM   #2 (permalink)
Lil_Bit's Avatar
This is a common swap.
Check advanced adapters for the tranny adapters as you should not have to replace the tranny and you would have to change the motor mounts.
The 4.3 motor is worth doing the conversion and has way more power.
__________________
90' 4Runner 2dr 4x4
K&N Cold Air Intake
Centerforce Clutch
35 Toyo M/T w/4 in. lift
Soon to come...
Gears & Locker
2 in. body lift & a V6 Tacoma motor swap
Warn Bumpers and winch
86' blue Toyota PU long bed 4x4
2 in. Body Lift & Add a leaf
33 Toyo M/T
529 Gears & Locker
Centerforce Clutch
Warn winch
Just Purchased
84' Beige Toyota Pu short bed 4x4
3 in. Body Lift
529 Gears & Locker
"When Hell Freezes Over, I'll Wheel There, Too!"
Lil_Bit is offline
Old 11-13-2008, 08:32 AM   #3 (permalink)
buckaaron's Avatar
can i make my own tranny adaptor?
__________________
Aaron
Upper Penisula, Michigan
94 4Runner 3.0 totally stock
Old 11-13-2008, 08:38 AM   #4 (permalink)
Lil_Bit's Avatar
Don't know. I guess you could try! LOL
__________________
90' 4Runner 2dr 4x4
K&N Cold Air Intake
Centerforce Clutch
Soon to come...
Gears & Locker
33 Toyo M/T
529 Gears & Locker
Centerforce Clutch
Warn winch
Just Purchased
3 in. Body Lift
529 Gears & Locker
Lil_Bit is offline
Old 11-13-2008, 08:42 AM   #5 (permalink)
Lil_Bit's Avatar
It would definitely be easier to just buy the adapters, but, if you know what your doing, I would try it.
__________________
90' 4Runner 2dr 4x4
K&N Cold Air Intake
Centerforce Clutch
Soon to come...
Gears & Locker
33 Toyo M/T
529 Gears & Locker
Centerforce Clutch
Warn winch
Just Purchased
3 in. Body Lift
529 Gears & Locker
Lil_Bit is offline
Old 11-13-2008, 09:20 AM   #6 (permalink)
buckaaron's Avatar
i have a buddy that is a fabricator and another guy that is just great at building stuff and making it work and be bullet proof also. I would just have to get the specs i think.
__________________
Aaron
Old 11-13-2008, 09:20 AM   #7 (permalink)
buckaaron's Avatar
i want to say thank you also.
__________________
Aaron
Old 11-13-2008, 09:24 AM   #8 (permalink)
Lil_Bit's Avatar
your welcome.
Hope ya have fun with that. We will be swapping out motors as soon as we find a tacoma motor.
__________________
90' 4Runner 2dr 4x4
K&N Cold Air Intake
Centerforce Clutch
Soon to come...
Gears & Locker
33 Toyo M/T
529 Gears & Locker
Centerforce Clutch
Warn winch
Just Purchased
3 in. Body Lift
529 Gears & Locker
Lil_Bit is offline
Old 11-13-2008, 03:39 PM   #9 (permalink)
Adam F's Avatar
Send a message via AIM to Adam F
Theres a handful of guys here that have completed the swap.
Did you not see the "domestic swaps" forum right next to this forum???????
Adam F is offline
Old 11-14-2008, 06:32 AM   #10 (permalink)
buckaaron's Avatar
no i did not i just registered and still trying to figure my way around here but thank you
__________________
Aaron
Old 03-12-2009, 05:10 PM   #11 (permalink)
SupraRunner's Avatar
Downey has a full swap kit here
http://www.downeyoff-road.com/Engine...rsionKits.html
SupraRunner is offline
Old 11-14-2009, 10:11 PM   #12 (permalink)
mazdamike's Avatar
3.0L D-4D in 90 4Runner ??? anyone
I would like to do a engine swap on my 1990 Toyota 4runner 4WD. I would like to put a 3.0L D-4D 1KD-FTV engine in my 1990 4Runner.
Does anyone know who has done this engine swap successfully?
Does anyone know if the 3.0L D-4D 1KD-FTV engine has a fuel pump in the fuel tank, or is it just a pick-up tube?
Do all 4WD models sold worldwide, have the transfer case on the right side?
If I use a manual trany from a 1990-1996 Hilux, Will this tranny bolt up to the newer 3.0L D-4D 1KD-FTV engine? If so, this would solve the speedometer cabal problem, and the drive shaft problem.
These are the problems I see, there are probably others I don't.
If anyone have any insight and knowledge to share I would really appreciate it.
mazdamike is offline
Tags
40, 43, 4runner, 94, comparison, cost, engine, images, kit, swap, swaps, tacoma, ticking, toyota, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
86 4Runner What engine swap should I go with?? rickybobby012889 Engine Swaps 20 10-25-2007 10:53 AM
1991 4Runner body swap or engine/tranny swap? 91slowrunner 86-95 Trucks & 4Runners 2 05-21-2007 10:11 PM
94 4runner engine swap onesimpleman 86-95 Trucks & 4Runners 4 05-03-2006 05:41 PM
4runner engine swap redneck 4runner Newbie Tech Section 3 02-09-2006 10:53 AM
85 4runner engine swap pablo55 95.5-2004 Tacomas & 96-2002 4Runners 1 05-27-2004 08:13 AM
2009 InternetBrands, Inc.
