| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
wire harness?
__________________
90 4RUNNER V6 3VZE (5VZFE SWAP SOON!) ISR MOD / EGR MOD / 3" PERFORMANCE BODY LIFT / 1.5" OVERLOAD LIFT COILS / 1" BJ SPACERS / KYB SHOCKS / 33"X12.5" BFG M/T / 421000KM |
#2 (permalink) |
bump*
__________________
#3 (permalink) |
what type of trans are you going with behind the 3.4 after its installed? If its a manual with a manual ecu with a auto harness then i think that you could make it work. i beleive that the a/t harness has more wires sense the computer has more to monitor but if you can sort out these wires then you may be set.
now if its the a/t behind the 3.4 with the a/t harness and a m/t ecu then it will not work. again im not for certain so do not qoute me. but it sounds logical to me. |
#4 (permalink) |
Yes you can make it work..
My truck was originally a 3.0L, 5-speed. Donor motor was a 99 tacoma auto. I used everythign from the donor and made it work with the auto ecu and harness. So to answer your question, YES you can make it work, just takes a bit of time and research.. I just jumped the park/neutral saftey switch to make the ecu think it is in neutral the whole time.. Runs fine!
__________________
Mike 1990 4runner: 3.4 swapped, 5-speed, sas'd, Rear leaf swap, Locked, 5.29's, 39.5" iroks on Beadlocks, Armor'd Longfields, Duals coming soon: My build thread http://www.yotatech.com/f152/904_run...thread-158746/ http://www.treadlightly.org/ http://www.pirate4x4.com/tech/billav...ery/index.html Last edited by 904_runner; 10-04-2009 at 10:14 PM. |
#5 (permalink) |
its a 90 3.0 5spd swap with a 99 3.4 5spd (not complete) but i also scored a complete but disassembled 97 3.4 auto. so my plan is to use the 99 5spd since it is newer has less km and mostly since its assembled. i want to use the 97 for parts, mostly the exhaust and wiring harness on the 99. follow? i wasnt able to get the ecu i wanted so no i have the option open to get either. so which would work better? the 97 a/t or the 99 m/t?
__________________
#6 (permalink) |
i would use the 99 mt personally..
What was not complete about it?
__________________
Mike 1990 4runner: 3.4 swapped, 5-speed, sas'd, Rear leaf swap, Locked, 5.29's, 39.5" iroks on Beadlocks, Armor'd Longfields, Duals coming soon: My build thread http://www.yotatech.com/f152/904_run...thread-158746/ http://www.treadlightly.org/ http://www.pirate4x4.com/tech/billav...ery/index.html |
#7 (permalink) |
the 99 didnt have a alt, p/s, wire harness, ecu...
but what i meant is what ECU will work best with 99 m/t engine and 97 a/t wire harness? i want to keep my swap as cheap as possible so lil bit of extra work is no issue.
__________________
#8 (permalink) |
I think you'll end up wanting to use the ecu out of a 97 m/t. I did mine with the 3.4 and harness from a 98 a/t 4runner but used the ecu from a 98 m/t tacoma. everything works fine. it's a bit of a pain to wire up the back-up lights, 4wd sensor but your speedo should still be a cable. I just cut all the plugs off for the a/t and grafted on the plugs for a 3.0 m/t and made everything line up at the jumper.
Good Luck Last edited by Jody; 10-06-2009 at 06:05 PM. |
