another 3.4 write up
crossover is done hope it works i used all the original tubes, like i said im trying to do the whole thing for under 1500 to see if it can be done, here are some pics,
3.0 dipstick
crossover
3.0 dipstick
crossover
Are you gonna be able to get to that top left bolt (near the flex pipe) when the bellhousing is attached??? Looks real close in that pic! Might be tuff to get the tranny in but could just be the picture!
Granted looking at it again with the bolts not on holding up the crossover it should pick up some it looks like away from the tranny!
Keep it up dude!
Keep it up dude!
#26
just an up date, for the clutch i used the 3.0 clutch, flywheel, pilot bearing, and throwout bearing, with the 3.4 starter. for the oil i used the 3.4 baffle, 3.0 pan, 3.0 sump and 3.0 dipstick, everything bolted together well and the motor and trans is mounted in the truck
#27
got the radiator, fan, exhaust, and steering hoses all hooked up, as well as the modified 3.4 alt harness, for the rad. hoses i used the both the 3.0 ones, my truck has abs so i used the 3.0 power steering hoses, all hoses fit perfect
