Vaccum Help V6
Vaccum Help V6
Anyone know where to get a detailed diagram or pics of the Vaccum line setup on the 3vze. Mine was dismantled while I was not around several months ago and now it's very difficult to put back together. I appreciate any help.
Thanks
Trevor
Thanks
Trevor
sacrifist@aol.com
Thanks that would be awsome.
Im having trouble sorting out the lines that run off of the passenger side of the plennum. There's a cluster of about 6 (2 sets of 3 lines)small lines all about the same size, then there is a vertical line of about 4 or five larger lines (varying size,maybe vaccum, not sure) but Im trying to get all of these sorted out. If you have anything that you think would help Id greatly appreciate it. If you need more info let me know Ill try to describe it better.
Thanks
Thanks
1 Post
Got two things for you - 1 photo & 1 scan.
There are a couple of double hoses to be hooked up. Sorry I didn't have time to trace mine and give you a better description. Not sure if it makes a difference which hose goes where.
Hope this helps.
Hope this helps.
