idle sucks - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Maintenance & Repair Archives
Welcome to Yotatech!
Welcome to Yotatech,
Old 04-14-2005, 12:17 PM   #1 (permalink)
idle sucks
alright Im needing some advice. my idle is fine until i drive it a bit, so basicly once it warms up, it drops and surges from 600 to 1100rpm when in neutral. when the clutch is in its fine though. all my hoses are good so im thinking tps? any ideas?
sefus is offline
Old 04-15-2005, 04:20 PM   #2 (permalink)
really need some help with this one guys. after its warmed up if im not on the gas it searches for an idle then dies.
sefus is offline
Old 04-15-2005, 04:40 PM   #3 (permalink)
cabbage's Avatar
Send a message via MSN to cabbage
Did you mess with the tps lately? Adjusting those is not fun at all!
Do you have a vaccum guage? Check and see if the bvsv is opening the egr valve at idle after the engine is warm.
__________________
Milton
01 Tacoma access cab 4x4 TRD TC Long travel, Supercharged
04 Tacoma Doublecab 4x4 TRD hoes all around!
cabbage is offline
Old 04-16-2005, 12:31 PM   #4 (permalink)
could you explain that one for me. im used to carbs... thanks for the help!
sefus is offline
Old 04-16-2005, 01:30 PM   #5 (permalink)
cabbage's Avatar
If I were you, i would first check to see if the ECU is sending any codes.
In case you dont know where the check connector to short is : click here The check engine light will flash, count the flashes to tell what the problem is. If there are no long pauses between flashes(or just a consistent flash), its normal.
__________________
Milton
cabbage is offline
Old 04-16-2005, 05:51 PM   #6 (permalink)
FingerMan20's Avatar
Uhhh... I dunno if this helps, but my brother's '95 Saturn did the same thing, raggedly idling after warm-up and just generally running weaker, and his EGR was totally spoiled... He gave it a good cleaning, and it was good as new.
Just a thought.
__________________
1998 Tacoma Standard Cab 4x4
-5 Speed
-2.7L 3RZ-FE
-80,000 Miles
-custom ISR Mod
-Purolator Fuel Filter
-Royal Purple
-Marlin Crawler Shift Stuff
-Lots of Plans
-No Money
FingerMan20 is offline
Old 04-17-2005, 11:17 AM   #7 (permalink)
awesome, thanks guys. keep ya posted.
sefus is offline
Old 04-17-2005, 06:47 PM   #8 (permalink)
hotshoe's Avatar
Sefus- I went through the same dam thing with my 92. I repalced the TPS and it didnt fix it. I pulled the idle adjustment screw and cleaned it and the TB out...........good as new.
TPS_ $98.00
Carb leaner_$4.50
Go figure!
__________________
00 Tundra Stonewell Body Ready for shoeing
97 T100 Under the Knife!
I am the Toe Cutter! Have you seen the Night Rider?
hotshoe is offline
Old 04-17-2005, 10:17 PM   #9 (permalink)
well i worked on it today. I ran the codes and according to Haynes I pulled a 4, 5, and 11. so I took the TPS off a spare manifold i had and went to take the one off the engine, realized i couldnt get to the bottom screw so took off the t-stat and hoses right before i realized it would be easier to take off the throttle body. when im putting the Tstat back on, one of the bolts strips out. i tried a heli coil but it didnt take so my t-stat housing is basically being held together by one bolt and a lot of form-a-gasket. got the tps changed out though and it seems to be a little better, but now my eyes are glued to my temp guage and rearview mirror for when I start losing radiator fluid. If its not one thing is another.
I did check the EGR vacuum thingamabob and the filters were pretty gross. the manual refered to them when you're getting crappy milage so all those looking to get that .11 better mpg you might want to clean or replace those little filters.
thanks for all the help guys.
sefus is offline
Old 04-18-2005, 02:14 PM   #10 (permalink)
is your tps set right? it takes some time rather than just "changing it out"...took me about 10 tries before i got correct readings.
callmej75 is offline
Old 04-18-2005, 02:32 PM   #11 (permalink)
It fixed my idle problem so thats good for me at this point. I set the mounting screws exactly where they were on both intakes but how exactly am I going to know if shes off kilter?
sefus is offline
Old 04-18-2005, 02:36 PM   #12 (permalink)
http://www.4crawler.com/4x4/CheapTri...#TPSAdjustment
Thats how I adjusted mine...4crawler is awesome PERIOD
Old 04-18-2005, 02:42 PM   #13 (permalink)
Yea, 4Crawler rules.
__________________
-5 Speed
-2.7L 3RZ-FE
-80,000 Miles
-custom ISR Mod
-Royal Purple
-Lots of Plans
-No Money
Old 04-18-2005, 08:11 PM   #14 (permalink)
Joyota's Avatar
Send a message via AIM to Joyota
Quote:
After doing the head gasket, and putting everything back together, I tried this same thing. The problem is that the tps is "very" sensitive. We're talking thousandths of an inch. Follow callmej75's advice and visit Roger's site. While you're there, check out the rest of his site. The guy is amazing. You won't regret it.
__________________
~ Joe ~ '89 4WD Pickup, Std Cab, 22RE, W56, 4.10's
{REPAIRS} Head Gasket, Timing Chain Guides, Water Pump, Alternator {MODS} Flatbed, Turn/Parking Light, SR5 Cluster, SR5 Lighter, SR5 Clock, 750W Inverter {ACCESSORIES} 33x12.5 on 15x8's (no lift), Radar Detector, CB, Contico Tool Box, Pilot Driving Lights, Fiamm Freeway Blaster {WAITING} Portable Air Tank, Big 3, Hood Scoop
Joyota is offline
Old 04-19-2005, 04:19 AM   #15 (permalink)
Quote:
amen....preach it brotha! i've been eyeballing then ball joint spacers for some time now on 4crawler's site...im getting very close to ordering!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
90 3.0 rough idle, bouncing idle, rich condition Chuki 86-95 Trucks & 4Runners 1 11-04-2006 03:57 PM
Outside temp effects my idle and a/c high idle. Chuki 86-95 Trucks & 4Runners 2 07-23-2006 12:10 AM
idle sucks freshman 95.5-2004 Tacomas & 96-2002 4Runners 3 11-14-2005 09:40 PM
400 RPM Idle drop when in Drive and idle variations Forerunner 95.5-2004 Tacomas & 96-2002 4Runners 4 10-10-2004 09:03 PM
Does low idle=more power & high idle=less? Yoter 95.5-2004 Tacomas & 96-2002 4Runners 1 08-13-2004 06:11 PM
2009 InternetBrands, Inc.
