Foam adhesive tape removal
Old 08-19-2004, 09:34 AM
rwmorrisonjr's Avatar
Location: Home: Aurora, CO; Work: The People's Republic of Denver
I had some VentVisors on my truck and have removed them, but the foam tape left a lot of adhesive on the doors. Is there anything that I can use to safely remove the adhesive w/o runing the paint? I've tried bug & tar remover with limited success.
rwmorrisonjr is offline
Old 08-19-2004, 09:36 AM
waskillywabbit's Avatar
Talking Goof Off
I used Goof off to get the remnants of my emblems off and it dulled the paint, but nothing a bit of polish didn't fix right up. Spray it, wipe off the excess off the paint, let it sit. Do that several times and then it will just rub right off like it ain't even there.
Good luck!
waskillywabbit is offline
Old 08-19-2004, 10:08 AM
grams72's Avatar
I would try the following
WD-40
or decal/stripe remover.
grams72 is offline
Old 08-19-2004, 12:23 PM
Bob_98SR5's Avatar
I wouldnt use Goof Off for the reason that Brian mentioned above. It is not paint safe.
There's another product with a similar name called "Goo Gone". It is biodegradable and paint safe. i have both in my garage and I almost always use the Goo Gone and have had no problems.
Bob
Bob_98SR5 is offline
Old 08-25-2004, 08:01 PM
Beachrunner's Avatar
There's some orange oil products out there that work awesome on adhesives. We use a generic brand at our sign shop for removing fleet graphics.
Beachrunner is offline
Old 08-26-2004, 07:44 AM
X-AWDriver's Avatar
My friend just left his truck in the sun for a while and when it was very hot he was able to remove most of it with some elbow grease and his fingers but he still used a little light adhesive remover to get the rest.
X-AWDriver is offline
Old 08-27-2004, 06:22 AM
WolfpackTLC's Avatar
Goof off is bad for paint, but works.. Goo Gone is better, but the best is sold at automotive paint stores, and is marketed by 3M as (what else) Adhesive Remover. It's about $10 for a can, but nothing else is better. (that I've seen anyway.)
WolfpackTLC is offline
Old 08-27-2004, 07:32 AM
X-AWDriver's Avatar
I have a can of that 3M adhesive remover and you have to be carefull not to rub too hard or it will mar the paint a little but it will work.
Old 08-27-2004, 11:17 AM
cruizin01's Avatar
DX-330 is the best at removing that type of stuff. I dont know what I would do without it. Stop by your local PPG supplier and pick some up.
cruizin01 is offline
Old 08-27-2004, 12:00 PM
terryjmatthew's Avatar
I Agree W/ Crzn01. Ppg Dx330 Wax And Grease Remover Works Well Although It Might Be A Little On The Steep Side For You.
Last I Recall It Was Around $30.00/gallon
terryjmatthew is offline
Old 08-27-2004, 04:32 PM
jrallan26's Avatar
Go to a body shop supplier and ask for some "Body Solvent". Its a safe solvent for glue and imperfections.
jrallan26 is offline
chukarhunt
12-08-2019 11:39 AM
Marsheen
02-17-2016 12:29 PM
Jcrawl94
10
10-24-2015 04:34 PM
JookUpVandetti
09-11-2015 09:41 AM
viesail
08-17-2015 08:39 PM
Quick Reply: Foam adhesive tape removal
