Engine Swaps Swapping an engine in your Toy, here is where to learn how
86 4Runner What engine swap should I go with??
Old 10-25-2007, 09:53 AM
rickybobby012889's Avatar
Originally Posted by idayota
well, as far as gears go, i went with 5.29 yukon's...those with 35's let me do 75 miles per hour on the freeway with a lightly built 22r. in my older 83 pickup i had the same set up with a stock 22r and it did just fine as well.
Ok you say use he 5.29 yukon with 35's iam wanting to go with a set of 37s will the gearing be appropiate for the small engine and big tires
Old 08-06-2012, 10:57 AM
19904runnerCali's Avatar
I have a 86 toyota pickup with Ifs and 4:10 gears, its 5 speed with 22r. I want to get more power with changing my rear end or tranny. So 350 and 4.3 from what i have read are out of question. And i want to stick with carburated. What should i do?
Old 08-08-2012, 05:39 PM
bigarms23's Avatar
swap in the one of the following if staying yota 3.4 or lexus v8 or a 4.3,4.8,5.3 depends on your budget
Old 07-24-2013, 01:30 PM
4runner_Arce's Avatar
Originally Posted by Turbo4Runner
Turbo the 22RE! Still capable of good gas mileage but the power is there when you need it. Plus turbo motors are just cool.
Check out Darin's website for tons of great info (DCG on this forum).
http://22returbo.net/
I am VERY happy with my setup. Still haven't gone to the Dyno, but I think over 200hp to the wheels will be pretty easy (and over 250ft/lbs). With very basic tuning i'm still getting about 18/19mpg (I run 33's and stock gearing) and its running rich. I haven't gone through a tank yet on the full turbo setup that didn't see some trail time.
I want to turbo my 1987 4runner 22re where can I get a kit to build and order it?
Old 11-28-2013, 08:43 AM
  #25
CodyRunner's Avatar
My 91 4runner has the 5vz-fe out of a 98 runner and I am very happy with the power. I drive about 75 to 80mph on the highway without a problem.
Goddamnboh
3.4 Swaps
12
05-11-2016 09:22 PM
vasinvictor
01-20-2016 12:39 PM
noahstancik
07-10-2015 11:18 AM
Alex Bessinger
06-28-2015 10:05 AM
TheManOutside
06-18-2015 03:32 PM
Quick Reply: 86 4Runner What engine swap should I go with??
