22R EFI Swap Need Help(No Fuel) - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Engine Swap Talk > Engine Swaps
Welcome to Yotatech!
Welcome to Yotatech,
Old 06-09-2009, 05:59 PM   #1 (permalink)
01mudslinger's Avatar
Question 22R EFI Swap Need Help(No Fuel)
Ok ive been running this through Pirate and have spent a good 4 hrs searching on the computer in the past 2 days and im stumped.
Swapped a EFI extended Cab on Regular cab frame. Done the EFI Swap on the 22R since cab was already wired for it.Cab and Motor both 1985. Plug and Play right. haha.
Every wire and connector was there execpt 1. 3 cut wires no plug, black-red, black-yellow, and black-white. This afternoon figured out that those 3 wires are supposed to plug into big connector on coil and run to the Computer. Got that all hooked up. Tried to crank it and nothing, It is getting spark to the plugs, but no fuel( Dry and no gas smell, plugs are NEW)
Went by the book and checked every single sensor, ECU, Injectors(Test light also showed power to the injectors), grounds(motor grounded to body and frame) fuses and relays, EVERYTHING checked out good by the specs in the book. Also pulled fuel line from motor and cut pump on and its getting fuel.
The only thing not hooked up is the VSV Fuel Pressure Control that mounts to the valve cover. I read 3 different things that says it isnt a neccessary item. Is this Correct? Why isnt the injectors spraying fuel? What lets the fuel to the fuel rail instead of sending it back to the tank? I am stumped Please HELP
01mudslinger is offline
Old 06-09-2009, 06:52 PM   #2 (permalink)
vital22re's Avatar
Send a message via AIM to vital22re
whats your fuel pressure reading at the fuel rail? are the injecters clogged? how long did they sit without running?
__________________
92 toyota truck 3.4 5spd 4.56 gears magna flow cat and muffler2 1/4 piping isr mod to intake 1.5 bjsfront add a leafs and 2inch lift shackles rear rancho shocks all around sitting on 265/75/r16 nitto terra grapplers
vital22re is offline
Old 06-10-2009, 02:58 AM   #3 (permalink)
Not sure on Fuel Pressure, its a External Pump, the E2000 Brand New. Injectors shouldnt be clogged cuz We cleaned everything prior to putting on motor. But all this EFI has been sitting for a long time.
Old 06-10-2009, 05:26 PM   #4 (permalink)
Didnt get a chance to check nothing this evening bad thunderstorms, i did check to see if the computer had any codes, and the Check engine light blinked 7 times. Whats that mean.
Old 06-11-2009, 11:53 PM   #5 (permalink)
rockdawg84's Avatar
make sure that the injectors are grounded. black and white wires that come together at a round end bolted to the intake manifold. i missed these and the injectors won't open without being grounded. start simple is what i say. good luck.
__________________
84 Runner streched and pounded but still crawlin
95 Runner about to be a fire Breather. I hope
rockdawg84 is offline
Old 06-13-2009, 08:08 AM   #6 (permalink)
Yea i checked the grounds and they were good. Thanks man, ive got it running now, its Idle is high, i started a different thread since it is running now. Check that one out and see if ya have any ideas. Thanks.
Tags
22r, 22re, 86, brand, carb, carburated, carburetor, efi, fuel, injectors, motor, plugs, rail, start, swap, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
1986 4runner 22r EFI not starting no fuel klove97220 86-95 Trucks & 4Runners 2 11-08-2007 12:57 PM
22r EFI Swap ride4x4forlife Pre 84 Trucks 1 08-09-2007 07:12 AM
22r EFI Swap ride4x4forlife Computer Talk 1 08-08-2007 07:24 PM
EFI swap 22r truck to 88 4runner efi parts yotanothing 86-95 Trucks & 4Runners 2 02-26-2007 05:40 PM
22R Carb to EFI Swap AKennedy87 95.5-2004 Tacomas & 96-2002 4Runners 20 07-01-2004 09:21 PM
2009 InternetBrands, Inc.
