Engine Swaps Swapping an engine in your Toy, here is where to learn how
22r to 22re swap writeup
Old 09-08-2011, 04:10 PM
87hillbillyoter's Avatar
Starting this thread more as a write up where people can go and find exactly what has to be done with pictures. and where questions can be asked. i will be doing this swap and taking a bunch of pictures. although i will admit, i have no idea what im doing. so any tips or tricks, post em up!
first off, here are a few links to check out if you are doing this swap. these are more for converting a carb'ed engine to FI. i am swapping an entire engine in.
http://www.pirate4x4.com/forum/showthread.php?t=316661
http://www.pirate4x4.com/forum/showt...hreadid=201142
pulling the engine this weekend hopefully. we'll see how it turns out
Old 09-08-2011, 06:31 PM
aquaprice's Avatar
I found it an easier process with a whole truck to pull the parts from.
Old 09-08-2011, 07:31 PM
it definitely would be. and thats basically what im doing, pulling it from my buddies truck and popping it in mine
Old 09-08-2011, 07:50 PM
SCToy's Avatar
Is it an early model 22re or a later model, pirate basically outlines the wiring for the early model, but leaves the later model 22re hangin :sadpanda:
Old 09-09-2011, 01:27 PM
i believe its from an 85. not sure on that though. still dont have the engine, my buddy is pulling it out of his truck next weekend.
Old 09-09-2011, 08:03 PM
bushrider's Avatar
does anyone one have info in swaping a 20r for a 22re on a 79 toad?
Old 09-10-2011, 04:31 PM
alright, so i figured id make this into a kind of step by step write up for all those who have no idea what they are doin. like me.
step 1: obviously, pull the hood off.
step 2: you probably dont have to, but i went through and marked every line there is. just in case this went bad, i could drop my old one back in there.
step 3: find everything that is connected to the engine that is also connected to the truck. disconnect all of it. check and re-check. i checked at least 4 times and i still missed a bolt and a ground wire. take the header/manifold off, all the air filter crap off, and vac and electric lines.
step 4: support the transmission and the engine.
step 5: unbolt all the bolts connecting the bellhousing to the engine. in my case, 2 were missing, and one had cracked completely through, so i only had 5 bolts to undo.
step 6: unbolt the motor mounts.
step 7: pull the engine. i had to yank mine a little to get it loose. had a little trouble getting it out of the engine bay because i didnt route the chains right.
oops! missed a wire
the engines resting spot :gap: by the way, this thing is for sale, if anybody is interested.
empty engine bay
and where im at on the dash- didnt try any more today, still cant find where its being held up at.
more on the writeup later.
Old 01-01-2012, 02:33 PM
lrnhw2dr's Avatar
I'm looking at putting a 22re head on a 22r block any input?
Old 01-27-2012, 09:48 PM
CFXY's Avatar
I want to convert a 22R to a 22RE fuel injected does anyone have any input on what all needs to be done to make this work.
Old 05-27-2012, 07:51 AM
1shop 4x4's Avatar
22re swap help
I know there's a lot of post about this swap but I don't see much on telling you what you need, I bought a 92 2wd for a donor truck for my 84 to do the efi swap. I pulled the motor and the harness and the ECM which was the one located at the kick panel on the passenger side. Is that all I will need for the swap? I'm just gonna run a inline fuel pump instead of swapping out the fuel tanks? Any info would help a lot
Thanks
sandyota
02-04-2021 11:16 AM
mskalmus
05-28-2017 07:51 AM
deepmarsh
08-06-2015 03:44 AM
cars-guy
07-11-2015 07:51 PM
Tyler Cunningham
07-11-2015 10:18 AM
Quick Reply: 22r to 22re swap writeup
