Toyota rear in a Mazda
Old 10-08-2014, 01:34 PM
mischief's Avatar
Hi all, I have an '87 Mazda b2000 that I want to swap a Toyota rear axle into.
I need it to be 58" wide so I think that would be pre '96 and I want to have a 4.56 ratio to run 235/75-15 tires. Since it is 2wd I would also at some point like to put one of the ARB air lockers in it. It seems, from the research I have done, that the only differential available with that gearing in a 58" wide axle is a '95 prerunner with a 10 bolt ring gear which is not compatible with an ARB locker. I'm asking for suggestions as to how to set up a 58" wide, 6 lug axle with 4.56 gearing and an on-demand locker.
Thanks for any help
Christi
Old 10-08-2014, 03:52 PM
peabody's Avatar
Subscribed because I have toyotas and ford courier (mazda). Can't help with lockers but for your reference, all my 86-88 toyota rears, stock, are 58", 4.10, and pushed 225's or 235's. Exception was the stock auto, 4.3 gearing.
Old 10-08-2014, 07:44 PM
mischief's Avatar
I have a stock 3.9 and we go forward but with such a small engine it's just too tall. The 4.3 would be better but I think even slower still would be better yet. I probably won't find one that narrow that will accept the arb
Old 10-14-2014, 08:36 AM
twistedyota's Avatar
Read this link
http://home.4x4wire.com/erik/diffs/
86-95 toyotas (1st/2nd gen 4runners, 2nd/3rd gen pickups) rear end measures 58.5 some came stock with 4.56 gears and you can buy arb lockers or e-lockers to fit in these housings.
Old 10-14-2014, 08:57 AM
mischief's Avatar
Thx, I found a '92 4runner that I think is going to work
Just have to get it under there now
Old 10-14-2014, 09:30 AM
No problem, also just to let you know, the 2nd gen 4runners were coil spring, so if your mazda is leaf sprung, ull have to cut the coil buckets off and weld leaf spring perches on.
Old 10-17-2014, 07:32 AM
mischief's Avatar
yeah
a lot more than just the spring pans to cut off, lol
Thanks for the help
Christi
6th Gear
19
12-10-2019 07:31 AM
Jmiller1023
23
08-06-2015 07:03 PM
Gamble_STi
07-01-2015 12:51 PM
cchinny
06-25-2015 08:11 PM
Quick Reply: Toyota rear in a Mazda
