| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
__________________
1992 toyota pickup 4x4 3 inch bodylift 33x12.5r15 bf goodrich all terrains rollbar with offroad lights |
#2 (permalink) |
There's a sensor on the top of your rear axle housing, for the rear anti-lock. Those go bad, and trigger the light.
First thing to check for the brake light is your brake fluid level. Welcome to YT.
__________________
87 4Runner, 22re, 5 spd, 4.88, ARB rear, Mile Marker PE8000, Downey Header, TG Sliders, 3" BL, Home Fab Front and Rear Bumper, WabFab Bikini Top, Rustoleum OD Green. Build Thread 98 Tacoma Prerunner, 2.7, 340k. 91 4Runner, V6. 5 speed, Pro Comp lift, 33's, Rock Crawlers. Sold. |
#3 (permalink) |
Checked break fluid already! It's full
__________________
#4 (permalink) |
The sensors in the brake fluid reservoir sometimes fail. You can test that at the plug, and check to see if the parking brake switch is functioning properly. If you haven't done all this already. Good luck.
__________________
#5 (permalink) |
how do i do that??? lol
__________________
#6 (permalink) |
got the break light off by unplugging the sensor and plugging it back in! the rear-anti lock didn't go so well we snapped the bolt off in the process of unpluging that one! so what do u suggest i do next?
__________________
#7 (permalink) |
I had one that was rusted in like that. It's a magnet inside the diff, that will break apart fairly easily. Then you have to remove the plastic part that's stuck in there. This is all assuming you can't get the sensor out now. As for the bolt, you will need a bolt extractor and drill for that one.
If you want to go about it the easy way....I've seen some people just buy a new sensor, plug it in, and zip tie it up out of the way somewhere. The light will go off, but the sensor wont be doing it's job.
__________________
| Tags |
| 100, 4runner, 93, anti, antilock, brake, light, lock, pickup, problem, problems, rear, sensor, stuck, toyota |
