Opening Circuit Relay
The Circuit Opening Relay controls the power to the fuel pump. Which is why it's sometimes refered to as the Fuel Pump Relay.
http://personal.utulsa.edu/~nathan-b...96circuito.pdf
Hey RAD 4Runner,I went to start my Runner and heard a clicking coming from my EFI relay, Found the 15 map EFI fuse next to it blown, swapped it & just turned the ING to the on pos and it blew agian, Cked the obvious wiring & found no problems that I could see, used my meter to ck countinuity on that fuse block & it sounded a dead short, Just trying to figure out were to start, Wiring issues scare the $&@! out of me...
4Crawler, Thank you for the advice, that seems to be the common issue being said , I plan on diveing into it this week, figure I might as well look into a small oil leak etc. etc. while I'm at it. Thanks agian.....
justdifferentials
14
06-11-2017 08:36 PM
runnermedic
13
09-21-2015 05:20 PM
EatChipsNow
09-09-2015 01:25 AM
May-39
09-06-2015 01:05 PM
