No Dash or running lights
1991 truck 2.2 re 5 spd
Ok so I have no dash or running lights! Yes I checked the fuses and it was fried so changed it and fried again so any one got ideas where the short could be??? or a diagram to help me out!!!
Does the fuse blow instantly, or just when you turn the lights on?
If you have a trailer light harness check to see if any wires are broken. Check the tail lights for broken wires too. All that stuff is on the same circuit. By any chance have you recently put in a new stereo? Cuz if you have a wire crossed there, that could be causing it also.
No new sterreo and it blows instantly with or with out lights on. No breaks in the tail light wiring or my trailer light cord. Also checked all the bulbs.
This is a link to the entire lighting system diagram:
http://personal.utulsa.edu/~nathan-b.../4lighting.pdf
That fuse was blowing in my truck too and it ended up being the illumination wire behind the dash.
Hope that link works for you.
dome light grounding out- cigarette lighter are notorious for gremlins
which fuse is blowing please ?
give us more info-nothing has changed ? this just started happening out of the blue? rain or dry up there? body damage? remote starter ?
4pin trailer connector not smashed at the bumper or where is it on yours? checked it with a tester? I just had a couple months frustration with mine....
ashersullivan88yota
01-18-2022 05:37 PM
06-01-2021 01:51 PM
Johntom240
7
07-13-2015 12:18 AM
