General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Headlights Turn Off When Using Signal
Old 03-29-2010, 02:53 PM
LangyLang's Avatar
Every once in a while my headlights will turn off and the high beam indicator will come on when using the turn signal. It is not consistent at all, sometimes it does it, sometimes it does not. For now I have been avoiding using the turn signal when ever possible while driving at night. Does this sound like a loose connection or a faulty relay?
Old 03-29-2010, 03:00 PM
4Crawler's Avatar
Check the contacts in the headlight/combo switch, they may be dirty:
- http://www.4crawler.com/4x4/CheapTri...eadlight_Combo
High beam indicator coming on says the headlight relay is still supplying power to the headlights, but if the low beam contacts in the combo switch open up, then the high beam indicator will come on.
Old 03-29-2010, 03:17 PM
LangyLang's Avatar
Are the switches fairly easy fix up?
Old 03-29-2010, 03:27 PM
LangyLang's Avatar
Sorry, did not see the link in your post. I will try that this weekend and see if I can save $130, thanks.
ghostmoney
01-28-2018 11:42 AM
Shoua
13
05-22-2016 05:19 AM
Dennisx2
08-04-2015 01:26 PM
rushw
07-18-2015 01:46 PM
icentropy
07-14-2015 10:23 AM
Quick Reply: Headlights Turn Off When Using Signal
