| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Engine fuse blowing
#2 (permalink) |
I had a similar problem on my 85 and 1 of my 87s. My problem turned out to be the main wiring for my dash. It had fallen down on the steering column and had worn through. It would blow the fuse at odd intervals that was extremely hard to trouble shoot. I finally took it to an electronics specialist and they fixed it.
#3 (permalink) | |
Quote:
Thanks for the info! I'll go check it out. I fugured it would a nightmare trying to find a short somewhere. I ordered the original service manual by Toyota and waiting for it to come in so I at least have the schematic to see what else may be sharing the same contact point with this particular circuit. Thanks again for your info! anyone else out there that may have experienced the same problem with a different source PLEASE let me know!! Aloha! |
#4 (permalink) |
this is an old thread i started a while back. I figured out why my engine fuse kept blowing and i thought i'd put it up here in case someone else runs into the same problem.
anyhow, i had a small oil leak coming from the rear side of the head cover. the oil eventually ran down the transmission which in turn soaked the reverse light connector located on the transmission. everytime i threw it in reverse the fuse would pop. Cleaned out the connector, replaced my head cover and no problem since. hope this may help others with a similar problem! |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Constantly blowing fuse. | crazn | General Electrical & Lighting Related Topics | 2 | 06-04-2007 10:34 PM |
| Blowing fuse | WSUWESTON | Pre 84 Trucks | 3 | 03-25-2007 10:12 PM |
| a/c fuse keeps blowing on my 88 3.0 | Kaiks | 86-95 Trucks & 4Runners | 2 | 10-08-2006 09:36 PM |
| More EFI fuse blowing issues... | Connolly | 86-95 Trucks & 4Runners | 4 | 05-15-2006 04:37 PM |
| EFI Fuse Blowing... | Churnd | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 05-18-2004 10:02 PM |
