General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
4runner rear window
Old 01-26-2007, 08:02 PM
slamb478's Avatar
4runner rear window
I have a 1993 4 runner and am beginning to have troubles with the rear window not wanting to go down. The prolem exsists using the exterior key switch and the interior rocker switch. I can hear a "click" in the rear of the truck when I activate the internal switch but the window will not move. If you beat on the tailgate while pressing the switch it works, sometimes. I have a friend who has a 1994 that is having trouble with their window going up. The window works fine going the other direction. Please help, you cannot open the tailgate unless the window is down.
Steve Lamb
Old 01-26-2007, 08:06 PM
4Crawler's Avatar
Likely a relay has gone bad. That is the classic sign, the click you hear is the relay coil operating, but if the contacts are pitted or burned, nothing happens when they try to close. The reason you hear the click is that the noise of the window motor, that would normally mask the click, is not present:
http://www.4crawler.com/4x4/CheapTri...arWindow.shtml
Old 01-26-2007, 08:09 PM
Elton's Avatar
welcome to yotatech
Old 07-28-2008, 12:53 PM
JustGiver_77's Avatar
Hey Did you ever figure this out?...I have the same damn clicking sound from my truck when I try and close the window. It rather sucks driving around in the rain with no back window?
Old 07-28-2008, 02:26 PM
4Crawler's Avatar
As noted on the web page I posted a link to above:
"But if the electrical contacts inside the relay are pitted or burned, they will not make electrical contact, even though the magnetic coil is pulling them together (the source of the click) and thus the load they control (i.e. the rear window motor) won't run (and thus makes no noise) and you now hear just the relay clicking. You can usually feel which relay is clicking with a finger touched to each relay in turn in the rear window module."
Old 07-28-2008, 09:09 PM
kraus's Avatar
hi all,
where can i find info on how to put the window into the rubber into the window channels pertaining the tailgate? I have the assembly done "the channels on and the rubber" but the window won't go into the rubber pieces..can anyone help?
thanks
06-01-2021 01:51 PM
MMA_Alex
25
04-18-2017 05:07 AM
lledwod
08-30-2016 01:03 PM
Jnkml
07-06-2015 01:20 PM
CJ94yota
07-03-2015 10:14 PM
Quick Reply: 4runner rear window
