Removing Locking Lugnuts - Without the Key - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Tech Write-Ups (Staging Area & More Articles In The Wiki) > Maintenance & Repair
Welcome to Yotatech!
Welcome to Yotatech,
Old 06-05-2006, 06:08 PM   #1 (permalink)
DoubleZero4x4's Avatar
Removing Locking Lugnuts Without the Key
By DoubleZero4x4
This idea came from a Corvette owner:
You need to get a 12 point socket that barely fits and drive it on tightly, 4-5 decent wacks with a ball pean hammer will do the trick. You have to make sure the slots in the socket bite into the lug nut. Use a manual lug wrench - not a pneumatic tool to loosen the lug. Slow even torque is the ticket. When loose the lug will be stuck tightly in the socket. Place socket in a vice and drive ilug nut out with a drift punch and repeat three more times. Then throw the stupid locks away and get some standard lugs from the dealer in town.
I can tell you that it worked!!! I pounded on a 19mm socket and used a breaker bar to turn it slowly. Worked like a charm. Once the locking lugs were loose I simply pulled up and down slightly so that the socket would loosen up on the lug. Went to the stealership and picked up 4 news lug nuts and tossed the locking ones.
__________________
2000 4Runner SR5 4x4 Sport
Mods: Crimestopper Remote Start Alarm - Deck Plate Mod - 400W Inverter - Limo Tint - K&N Air Filter - Tundra Brakes/w Ceramic Pads & PowerSlot Rotors - Hayden Trans Cooler - Goodridge SS Brake Lines
2000 4Runner LTD 4x4 - Wife's
Mods: Deck Plate Mod - Tundra Brakes/w Ceramic Pads & PowerSlot Rotors - Goodridge SS Brake Lines - 400W Inverter
DoubleZero4x4 is offline
Tags
94, corvette, key, lock, locking, lug, lugnut, lugnuts, lugs, nut, nuts, remove, removing, socket, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
LugNuts, I dont have the key socket!! help asap!! 91muddog General Vehicle Related Topics (Non Year Related) 7 05-21-2007 11:26 PM
4 Locking Lug nuts (OEM) with key mrmojorisinphan The Classifieds GraveYard 3 09-29-2006 09:24 AM
Removing Locking Lugnuts - Without the Key DoubleZero4x4 95.5-2004 Tacomas & 96-2002 4Runners 6 06-06-2006 11:31 AM
does anyone make black locking wheel lugnuts? Brendan General Vehicle Related Topics (Non Year Related) 4 03-10-2006 01:19 PM
2009 InternetBrands, Inc.
