Spider Gears: Is This Normal?
I'm getting ready to remove my Aussie locker and put spider gears back in. Without thinking I got rid of my spider gears when the locker was put in. I just got some used gears to replace the locker with, but they just don't look right to me. I cant remember exactly how my old gears looked, but it seems like the teeth should not be curved. From all the searching I've done, all the spider gears I've seen have had straight teeth. Heres a couple pics, notice how the teeth are not straight, and curve in the middle.
i have a IFS diff tore apart right now, and i will check in the morning to see if they are. im pretty sure they are suppose to be curved. they have a little bit of slack in between the teeth when they are assembled. mine is a 92 diff though, but they should be similar since lockers for them are the same, you diff just has a reverse cut ring gear
He's asking about the rear ends.
Heres a pic of a spider gear out my Tacoma non TRD 8.4 rear. They have about 105K miles on them.
Yours look normal.
zombie_barbarossa
10-02-2015 10:54 PM
hiluxinargentina
09-30-2015 11:12 PM
charlie_fong
09-27-2015 10:06 PM
