?'s about weber 32/34 install 22r
I am installing my new weber kit tomorrow and have a couple questions about the instructions.
1. Electric choke and idle cut off solenoid need a key hot power source. What did you guys tap into?
2. Do I need to put any thread tape on the vacuum fitting to the egr plate?
3. It says to remove the manifold studs, but never says to install them again. I assume I use the ones that are in the kit.
4. It says to replace the throttle linkage with the longer one that came in the kit. The longer linkage has two holes, which one do I bolt through?
Thanks everyone
Thanks everyone
Thanks everyone
Thanks everyone
22r, 32, 3234, 36, black, carb, carburetor, choke, engine, install, installation, installing, plastic, spacer, weber
